Move to Next Breakpoint?
Hello,
I've been searching on the DUC, couldn't find the answer. Is there anyway, shortcut to move to the next automation breakpoint, like Tab to transient? Please let me know. Best Watanabe |
Re: Move to Next Breakpoint?
Not possible.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Thanks... Is there any altanative way you guys do?
What exactly do you want to do once having reached the breakpoint?
Tim |
there are so many things to do... move it up or down, delete it... well a lot.
...SHIFT-Select to next breakpoint, etc...
cheers, rich |
- Option-Click deletes the breakpoint. Unfortunately there is no shortcut for jumping to the next breakpoint, but as you need the mouse to edit the breakpoints, I think that shortcut is not that important - although not entirely useless. Following shortcuts might help, though: - Scroll horizontally: Option+PageUp or PageDown - If you have (at least) two breakpoints within a selection, press option while adjusting and the automation within the selection is altered in proportion. - Command+/ creates a breakpoint. Hope this helps, Timothy |
Is this still the case? I'm trying with no luck |
set a breakpoint to 0 db | oNeKOG | Windows | 3 | 10-16-2015 08:24 AM |
Move the red diamond in the tempo bar in the edit window, only some tracks move | kingheartless | macOS | 2 | 02-21-2013 03:20 PM |
Value for Automation breakpoint? | perh | macOS | 3 | 09-22-2012 05:35 AM |
Breakpoint move line in edit window:How to disable | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-12-2007 12:36 PM |
Automation and Breakpoint Changes | New Hope Media | Pro Tools TDM Systems (Mac) | 0 | 11-16-2005 06:20 PM |
