Old 04-16-2017, 12:12 PM
aspen1135 aspen1135 is offline
Default Lane Automation Zoom
Starting from other DAW's and migrating into Pro Tools has been fun and frusterating. One thing I can't really get over is how crappy (IMO) the automation is. The most frustrating part is when trying to use VCA's and automating parts with break points, a 2db + or - change can be really close to the other break point and hard to edit/select. How can I zoom the lane and get a better view of what I'm doing? Also, is there a quick way of doing this via a keyboard shortcut? I'm not a fun of doing everything with clicking toolbars.
Old 04-17-2017, 09:43 AM
john1192 john1192 is offline
Default Re: Lane Automation Zoom
in the automation lane itself you can make that Re-Size just like any other Track .. you can manually drag the bottom the bottom left corner of the Lane itself (not the track) or you can automatically by choosing a size ..
hope this helps ..
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 04-17-2017, 12:42 PM
TrentWilliams TrentWilliams is offline
Hold command while you click+drag, that will draw inautomation break points at 0.1 intervals
Pro Tools 2020.5|Ultimate, UAD Apollo 8, UAD Octo+Quad Satellite, UAD Apollo Twin Quad Core, Focusrite 8PreXiMac 27" Late 2013 - 3.5GHz i7 - macOS 10.15.6 • RAM 32GB DDR3, GPU NVidia GTX 780M 4GB
Old 04-17-2017, 01:35 PM
hope this helps ..
This works but I have to resize the window to basically take up the whole screen so I can make precise changes, even in .1 intervals. I just want to be able to zoom in the lane almost like you would with a waveform and see a higher resolution of the automation grid, without disrupting the entire session by taking up all the screen space!
Old 04-17-2017, 01:41 PM
Have you tried hitting 'E' to zoom in on the automation line?
Old 04-17-2017, 04:00 PM
thats better ...
RME BabyFace Pro
RME BabyFace Pro
Old 04-17-2017, 05:01 PM
Drew Mazurek's Avatar
thats better ...
Pretty soon, you'll have learned enough about it so it's not crappy anymore.
www.drewmazurek.com
Old 04-18-2017, 10:49 AM
The Weed's Avatar
The Weed The Weed is offline
Or Alt/Option+Scroll?
Or "R" or "T"?
Or setting a Zoom level using the Alpha 1-5 numbers?
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 04-18-2017, 12:54 PM
You can choose your 'E' zoom settings in preferences - to change the display options on zoom.
Scale an automation lane? theom Pro Tools 12 13 11-02-2017 12:05 PM
Volume Trim lane vs Automation Cliffy_Boy Pro Tools HDX & HD Native Systems (Mac) 12 03-06-2013 03:19 PM
No Send Pan automation lane on 9.0.3? Craig F macOS 1 04-21-2012 12:12 PM
automation bug in bypass lane Postman Post - Surround - Video 8 01-04-2012 06:20 AM
Automation lane size not remembered Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-07-2010 09:26 AM
