Old 03-24-2005, 04:28 AM
strizzack strizzack is offline
Default Using MIDI Controller w/ Pro Tools?
Is it possible to use a midi controller with Pro Tools? If so, how would I load the samples onto the midi controller so they are playble into Pro Tools? I assume I'd need an extra device, but I'm not sure.
Right now I'm just using Reason to program all my MIDI tracks. Then I import them into Pro Tools via Rewire. If there was a way around using Reason, where I could program sequences directly from my midi controller to Pro Tools that'd be sweeeeet.
Thanks.
Old 03-24-2005, 06:51 AM
cruisemates cruisemates is offline
Default Re: Using MIDI Controller w/ Pro Tools?
Obviously, Protools has its own midi functions. There is also an "import midi files" option under the File menu where you could import all the midi files from your Reason sessions.
- but the second mouse gets the cheese
Old 03-24-2005, 11:36 AM
IntelDoc IntelDoc is offline
With REWIRE you can assign individual REASON instruments to a MIDI channel and play it that way. You could then technically put the MIDI track into loop record mode and loop it to record what you want. So yes, it is possible to make REDRUM only play on your Midi keyboard.
I think it would be selecting a MIDI track, assigning the input to be the controller and then have it trigger to the REDRUM which should be in the output list. I know that it is possible, but I forget how to set it up.
Definitely doable though. I will try to get a template setup later if I can and show ya how.
Is that what you were after?
- Doc
MONUMENT SOUND
MONUMENT SOUND ON YOUTUBE
Monument Sound Facebook
"Changing how people hear music one track at a time"
Old 03-24-2005, 11:50 PM
Yeah, IntelDoc...you summed it up for me. Thanks a million!
MIDI Controller for Pro Tools Marcus_Aurelius Pro Tools 10 3 02-28-2013 12:54 PM
Using Pro Tools As A MIDI Controller pavkovlr Pro Tools M-Powered (Win) 1 11-14-2011 02:24 PM
Using Pro Tools without a midi controller? Simrin MIDI 4 12-21-2008 12:22 PM
Using MIDI Controller with Pro Tools. Need Help Jfarbs525 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 10-15-2008 08:44 AM
Pro Tools Doesn't See MIDI Controller ReverbMerv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-01-2006 03:57 PM
