Protools - not hearing guitar (PT 10, Axe-Fx II, Windows 7)
Hi community:
Total newb. What I'd like: I'd like to hear and ultimately record the guitar via an armed track. I cannot hear the guitar in Protools. I have no idea how to properly set up the AxeFx to work with Protools, nor what settings in Protools to set to work with the AxeFX. I do have a recorded track in Protools I have saved that I recorded a few years ago (last time I used this setup, but I moved, disassembled, and nothing is set right anymore) and I can hit play in Protools, hear the track through the monitors, but it's distorted..as if I'm hearing the recording through the AxeFX. This is when the AXEFX is set for MAIN INPUT SOURCE USB. When I set AXEFX for MAIN INPUT SOURCE ANALOG (IN 1) I hear the prerecorded track just fine. I'm guessing it's that I don't have anything set right. Total newb. Sorry. Would greatly appreciate some assistance in getting everything to just work. It's going to be quite a learning curve when everything is set up. Can't seem to even get things set properly. For what it's worth, I do have a Digi 002 at my disposal. It's sitting next to these units, not hooked up. Also note, when I exit Protools, change the AxeFX setting I/O, Audio, MAIN INPUT SOURCE back to ANALOG (IN 1) my guitar/AxeFx work just fine through the AxeFX and studio monitors. My hardware/software: Protools 10.0.0 Windows 7 Enterprise SP1 Axe-Fx II Firmware: 17.04 Jan 12, 2015 Mackie HR824 Studio monitors How I'm currently set up, roughly: Axefx connected to PC via USB. Same PC running PT 10. Guitar plugged in to front of AxeFx II. ********************** WINDOWS ********************* Under Windows OS sound menu, I have the following options under the "Playback" tab: Speakers (2-Axe FX II) Digital Audio (HDMI) 2 - High definition audio device not plugged in Speakers High definition audio device not plugged in Headphones High Definition audio device not plugged in Digital Audio (S/PDIF) High definition audio device Ready Speakers USB Audio Device Default device Under the "Recording" tab: Line, 2 - Axe-Fx II Default Communications Device, Ready Microphone, High Definition Audio Device, Not plugged in Line In, High definition audio device, not plugged in Microphone, USB Audio device, Default Device ***************** Protools 10 *********************** Setup -> Hardware Setup: FAS USB Audio ASIO Driver When I launch setup app I have: "Status" tab: Usb Audio Device: AXE-FX II Current Sample Rate: 48000 Hz "Buffer Settings" tab: USB Streaming Mode: Safe Asio Buffer Size: 2048 samples "Info" tab: Manufacturer: Fractal Audio Systems Product: AXE-FX II VID/PID: 0x2466/0x8003 Revision: v0.00 Serial No: Driver info Version 2.23.0 Release Build Setup -> Playback Engine, gives following message: "Your audio device is configured with an unsupported audio buffer size. Please select one of the following supported buffer sizes in the device control panel: 32, 64, 128, 256, 512, 1024, or 2048." OK. When I click OK I get the following window: FAS USB Audio ASIO Driver Settings H/W buffer size: Host processors 2 processors CPU Usage Limmit: 85% Host Engine (is checked) Ignore errors during playback/record (may cause clicks and pops) (not checked) Minimize Additional I/O Latency Delay Compensation Engire: None OK ******************** Axe-Fx II *************************** At the back of the Axe-Fx II: OUTPUT 1 L/R --> going to the Mackies. Under I/O, Audio: Main Input Source USB INPUT 1 LEFT SELECT FRONT . . .
ProTools 10 v10.0.0 Windows 7 Enterprise Sp1 Digi 002 Rack Axe-Fx II Firmware: 17.04 Jan 12, 2015 Mackie HR824 Studio Monitors Last edited by augustaga; 08-27-2015 at 09:35 PM. |
Re: Protools - not hearing guitar (PT 10, Axe-Fx II, Windows 7)
Remainder screen shots. Any help is greatly appreciated.
ProTools 10 v10.0.0 Windows 7 Enterprise Sp1 Digi 002 Rack Axe-Fx II Firmware: 17.04 Jan 12, 2015 Mackie HR824 Studio Monitors |
Have you installed the drivers as described in the Axe-FX documentation? Those drivers claim to be supported on your OS? (looks like you did).
Does any playback of pre-recorded content in Pro Tools work? Windows audio crap should gave nothing to do with anything here. Make sure Windows audio is *not* trying to use the Axe-FX as an interface. Your IO labeling is all screwed up (it reflects your 002 not the Axe-FX). In the IO>Input, Output and Bus pages clock on each item there and click delete. Then click the default button. Then you should find Inputs to Pro Tools that look right for being the Axe-FX outputs. What monitors/speakers do you have and where are tehy connected? Hopefully to the Axe-FX outptus... and the Axe-FX works fine stand alone with those? Try toggling between Input>Auto Input and Input>Input Only monitoring in Pro Tools. Read the Pro Tools reference guide to understand what this does. Remember the Axe-FX only works at 48kHz, you must create your Pro Tools session at that sample rate. That all assumes you want the Axe-FX to be the interface, if you want the 002 to be the interface then you can hang the Axe-FX as an outboard processor off the 002 via S/PDIF or line-level connections. Last edited by Darryl Ramm; 08-27-2015 at 09:49 PM. |
I'd be willing to do a paid skype session to get it going. Let me know if anyone is up for that. Thanks again for any help.
Any takers on a paid skype session to get things going? Please let me know. I've not had anyone respond yet. Thank you in advance.
I can't easily do skype, but I gave you a bunch of important things to do before like defaulting the IO that was obviously messed up and you did not do that? So this time how about trying to do all the following....
For right now we need to get you going, so don't think, just do. And you'll likely find what was wrong by just doing this. If you don't understand how to do something I am happy to help explain, but I can't debate/discuss each step. The guitar is connected to the Axe FX II and works OK out the Axe FX II in stand alone mode. The Axe FX II needs to be connected to the USB port on your PC and to the guitar, nothign else. No other interface is connected to the computer. Make sure the FAS device is selected as the playback engine (as your previosu screen show showed, but even better hold down the 'N' key while starting up pro Tools and make sure it is selected). Create a new session in Pro Tools. An empty session not from a template, not a copy of an existing session. It has to be a 48 kHz session (don't think, make sure to select 48kHz in the dialog box when you create it). Create a new audio track. Make sure it is a **stereo audio** track *NOT* an instrument track. Create just that single track, nothign else. Select the output of the Axe FX II guitar rig as the input to that track, basically you are after whatever the the Input 0/1 stereo pair is called. Select that as the input to that stereo audio track. (Post a screenshot o the IO>Setup Input and Output pages if this is not clear). In the Axe FX II setup menus you need to set the output to that input 0/1 pair to be whatever of the two outputs from the Axe FX II rig processing you want. e.g. Out 1 or Out 2. See the Axe FX II docuentation. Set that stereo audio track output to Output 1/2 (or whatever that ends up being called once you reset the IO). Now record arm that track (red record indicator lit). Do *NOT* press play, or record on the Pro Tools transport. Leave the track fader at 0dB. Play the guitar. Do you hear anything out the monitors? LED meters on the Axe FX II move? The track meter in Pro Tools move? If you don't hear anything report back. Include screen shots of the Pro Tools mix windows showing clearly the track IO assignment buttons. If you did hear the guitar playing, then press the transport record and then play button and play the guitar for a while then press the transport stop button. Did you hear the guitar while you were recording? Is a waveform recorded on the track? if does not look like it are you zoomed in vertically enough? If you did not hear anything while recording, Try hitting CTRL-K once and repeating the same recording steps. That work? ---- If things like getting a track into record mode or zooming in on a track are not obvious, open up the Pro Tools Reference Guide PDF that will already be installed on your PC and search for those terms. And if that does not help then ask back here. That documentation can be a bit intimidating, but is really good to know you way around. |
Hearing a guitar using Amplitube while playing back other tracks? | KD11520 | Pro Tools 9 | 4 | 01-02-2014 12:59 PM |
Hearing other strings on guitar that I'm not touching | bryced87 | macOS | 9 | 11-02-2013 06:35 PM |
Pro Tools 10 Pedal Steel Guitar and Mandolin Plug-in Windows | phefner84 | Virtual Instruments | 2 | 07-17-2012 11:19 AM |
problem hearing guitar | oplatner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-10-2012 08:54 AM |
ProTools HD 10 on PCIx Core card ... am I hearing things? | cburgett | Pro Tools 10 | 2 | 11-10-2011 10:36 AM |
