Re: What's the most current and stable PT/OSX combo?
10.3.7 on 10.8.5
Super stable on two systems here. Also have 11.2.1 on them. 11 doesn't crash, but inserting, opening, adjusting plugins constantly kills the audio engine and causes the garbled sound until you go to playback engine and adjust the buffer lower or higher. Doesn't matter which. 11 is never open when clients are present. Too embarrassing. |
That's the combo I'm going to go with.
I'm still unsure about the uninstall and my plugins. I want to avoid this:http://duc.avid.com/showthread.php?t=346397 I've also read there are 3 uninstall options, but I don't know which I should use. I've never uninstalled PT before.
System Details |
You all know how bad the avid site is. This page is out of date and incomplete:
http://avid.force.com/pkb/articles/e...kbase&filter=0 For example, there's no mention of 10.3.5 under the co-install heading. Even the compatibility info at the top does not match the 'compatibility chart' Can someone please (pretty please) answer these: 1. Can I update OSX before I uninstall and re-install PT? Or should I uninstall first? 2. With the co-install, do I have to install them separately or is there a combo installer? 3. From where do I get the uninstaller? Is it part of the install package or something separate 4. Will I have to re-install all of my plugin or will the uninstall leave them alone? 5. Are there secondary installers I have to run, such as AI plugins, and VI stuff? 6. Will I have to re-do all my PT prefs and OSX optimizations? Can I just import PT prefs file?
System Details |
Yes, you should. Either way, make a bootable backup first. Quote:
OSX optimizations should remain if you are upgrading an existing OS.
Thank you Jonhathan. What about my third party plugins? Will they be deleted with the uninstall or will they be left alone?
System Details |
#16
I am searching. And I'm not the only one with these questions:
http://duc.avid.com/showthread.php?t=328408 I've had a very fun time with past updates trying to track down impulse, VI's, plugins, etc. that were deleted, or not included in the new install, or whatever else. Hence my extreme caution. I believe it was PT8. But it seems like I'm either going to spend hours before hand at the avid site and DUC trying to piece together the proper work flow, or hours afterwards trying to piece together whats missing. Either ways its hours needlessly spent.
System Details |
#17
You are welcome! Third party plug-ins will be left alone.
#18
Well, I updated to OS X 10.8.5 and PT 10.3.7. Most things seem okay.
But I am having a crash when I close a session that has an Extra Long Delay with the feedback set at 80%. When you stop playback, the delay is still reverberating. If I close the session right then, PT sounds its own very annoying feedback loop and won't stop until I close PT. The plug in crashes. This didn't happen before the updates. I have more testing to do.
System Details |
#19
Quick addendum to above post. I don't necessarily have to close pro tools for it to stop. If I open another session so that something else loads into the sound engine it goes away as well. But if I do nothing it continues.
System Details Last edited by right beside; 09-05-2014 at 08:55 PM. |
#20
This is the crash I'm getting with this update:
https://www.youtube.com/watch?v=IrVa...ature=youtu.be Sorry but the lens on my iphone was dirty when I took the video. If it's not clear this is what I'm doing in the vid: Start play to trigger delay Stop play and let delay reverberate Close session while delay is still reverberating Pro Tools yells at me Quit Pro Tools and it stops yelling. Alternately, I can just open a different (or the same) session. I've also heard other noises throughout the day when PT is open but always when there is no session open. Opening a session eliminates the noise as it resets the audio engine to the new session. But there is some kind of bug or compatibility issue that is causing PT to generate noise when there are no sessions opened. Has anyone else experienced this?
System Details |
what is the most stable pro tools/ os combo since pt 7.4 and os 10.4.11? | ejsongs | macOS | 5 | 07-22-2014 04:35 AM |
most stable OSX/ PT 10 combo? | mr xy | macOS | 1 | 11-07-2012 05:54 PM |
Logic 7, HD3, G5. Anyone have this combo (stable)? | skillethead | Pro Tools TDM Systems (Mac) | 5 | 11-16-2004 12:50 PM |
What's a stable OS 10.2.x / PT combo? | Studio Dweller | Pro Tools TDM Systems (Mac) | 4 | 03-11-2004 08:01 AM |
Most Stable OS/PT Version Combo? | Bezo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 26 | 01-29-2004 09:58 AM |
