Old 02-01-2013, 05:18 AM
Arve Gotfredsen Arve Gotfredsen is offline
Default Channel I/O keeps loading old I/O and not "no input"/"no output"
Hi
When mixing I prefer not to have any inputs on my channels, but even though I set it to "no input", Pro Tools keeps loading the I/O from the interface I recorded with which isn't the one I'm using now.
It does not change the I/O setup for the session though, so the are all greyed out when loading the session.
Any suggestions how to avoid this?
Old 02-01-2013, 07:59 AM
crizdee's Avatar
crizdee crizdee is offline
Post Re: Channel I/O keeps loading old I/O and not "no input"/"no output"
Originally Posted by Arve Gotfredsen View Post
Hi
In the i/o setup page there's an option for " sessions overwrites current i/o setup when opened"
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-04-2013, 02:23 PM
Default Re: Channel I/O keeps loading old I/O and not "no input"/"no output"
Originally Posted by crizdee View Post
Chris
Thanks Chris, but that doesn't change anything. Look at the pic I attached, I'm talking about the greyed out input, and in this case I recorded on a Venue, but now it looks like this every time I load the session again...
Cheers - Arve
Old 02-04-2013, 02:42 PM
bad jitter bad jitter is offline
Same situation here. As a workaround I have changed the input first to some current one, saved the session and then changed It to none. That seems to work.
Old 02-12-2013, 04:38 AM
Yes, that works indeed. Don't know why this happens tho.
Cheers
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
Protools LE 8 hang while "setting up peripherals" and while "loading tracks" xfarre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2011 07:37 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... leon777 Pro Tools TDM Systems (Mac) 21 10-15-2002 12:00 AM
MTC input disabled when "Beat clock to port.." or "MTC to Port..." is enabled OKden Pro Tools TDM Systems (Mac) 2 10-27-2001 03:24 AM
