Old 03-02-2003, 01:32 PM
kmt kmt is offline
Default Ethernet again...
I'm trying to open PTLE sessions hosted on a server via a 100BaseTX Ethernet from a workstation. PTLE (v5.0.1.337) tells me "PTLE session must be on a valid audio drive. I use TCP/IP, and normal Ethernet (except PTLE) works fine, but I think it would be a waste of time to copy the whole session onto the workstation's drive every time I want to use it.
My operating system is Win98SE with Digi001 and a Asus MB with PentiumIII 900MHz. The server has a Asus MB and a AMD Chip, but only hosts the session and audio data.
So what am I doing wrong?
Thanx for any help!
Kai M. Tegtmeier
Old 03-02-2003, 01:36 PM
Stone Knife Stone Knife is offline
Default Re: Ethernet again...
What am I doing wrong?
You are not believing what the message tells you. You have to copy the session to your hard drive just like it says. [img]images/icons/smile.gif[/img]
Old 03-02-2003, 02:54 PM
Shan's Avatar
Shan Shan is offline
Unfortunately we cannot stream audio thru ethernet yet. I'm sure one day the speeds will allow us to do that. I have 3 Digi stations all networked together and what we do is import the tracks from the main session that need to be worked on. When you import select 'copy from source'.
Shan
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Anyone tried ATA over ethernet? mtung Pro Tools TDM Systems (Mac) 4 12-12-2007 06:32 PM
ETHERNET HUB FOR PC MICFREAK ProControl, Control|24, Command|8 2 05-24-2005 06:56 AM
G3 + 001 + G5 + Ethernet? dreamers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-21-2005 10:44 PM
Mac Ethernet help?? David Lawler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-14-2002 07:12 PM
ethernet... jwhartmann Storage Subsystems 1 05-13-1999 10:27 AM
