Old 11-18-2018, 12:24 PM
easyrider easyrider is offline
Default New laptop mobile recording and mixing
I’ve just bought a new laptop to run Pro Tools. To allow me greater freedom and flexibility.
My main interface is an Audient ID 22 and I connect an Audient ASP 880 mic pre to record drums etc...
My question is can I start a new session using current hardware then mix and record and continue the same session elsewhere with a different interface ?
Cheers
Tech:Quantum and ASP880 / Yamaha MT120S / Ryzen 5950X /Win 11 Pro 64-bit /Pro Tools 2023.12/ Shure DMK57-52 /Neumann TLM 102/ Oktava MK-012
Mic Pre's Focusrite ISA One/ DAV Electronics BG1/ Joe Meek VC3
Guitars and Instrumentation:Gibson Les Paul Zebrawood/Fender USA Telecaster/Fender Deluxe Strat/ Martin OM-18V/
Martin D15-M/Gibson SG Bass/ 1972 fender Musicmaster Bass/ 1972 Hayman Drums /Vox,Fender Amps/Roland F130R
Old 11-18-2018, 01:01 PM
BScout BScout is offline
Default Re: New laptop mobile recording and mixing
Yes
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 11-18-2018, 06:44 PM
Southsidemusic's Avatar
You will need to setup the i/o on the second interface as they probably won't be the same settings.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 11-20-2018, 05:32 AM
JFreak's Avatar
JFreak JFreak is offline
yea, and the settings can also be saved and loaded, so if it is too much trouble for you in every session you can help yourself with a simple file exchange
Janne
Old 11-20-2018, 11:17 AM
Great, thanks
If I run into issues I’ll post my question here if that’s ok
Old 11-20-2018, 04:50 PM
JFreak's Avatar
Tell me again why are we here?
Janne
Old 12-14-2018, 03:39 AM
Just been looking at a RME Babyface Pro and it seems I could use my Audient ASP 880 with the Baby face pro over ADAT to record my drums etc...
But also because its bus powered and portable use it with my laptop on the move.
This would negate the need to swap interfaces etc...
Hmmmm do you think its worth selling my Audient iD 22 and getting a Babyface pro instead?
Both for laptop and studio use?
Is the Babyface pro a step-up from the Audient iD 22?
I'm all for consolidating gear if its worth it.
Old 12-14-2018, 10:00 AM
JFreak's Avatar
I think they are more or less on par soundwise but RME might be more suitable for portable use
Janne
Mixing for Games, Apps and Mobile Web tonejunkee Tips & Tricks 0 03-07-2014 08:44 PM
Laptop Mobile card theblasters Pro Tools TDM Systems (Mac) 1 03-24-2009 09:37 AM
New LapTop for mobile recording-HP nc8430 or ASUS? PetrosGls 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-20-2008 04:16 AM
advice on mobile recording... tim carter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-19-2006 08:12 AM
mobile recording rig options Buffalo Bob General Discussion 3 03-07-2002 07:17 AM
