Unable to detect digi 002 AND 003, multiple systems.
I've had an 003 working fine on my winXP system for over a year now. Occasionally I'd get a detection error when starting up PT8 but I'd just turn the digi rack on and off and it'd work right away. A few days ago when I turned on the rack it went through its normal boot sequence but ALL the bottom LED buttons stayed lit. From then on, nothing will recognize the 003 hardware. The boot sequence seems fine, only mute LED stays lit, normal clicks, the back "link" firewire LED lights when firewire is connected but no system detects my 003. I've tried multiple firewire cables, PCs running XP and Windows 7 with fresh ProTools installs, same for OSX.
After borrowing an 002 for a few days, it was working fine then the same thing happened. Except for the LEDs staying on I can't get any system to detect either interface. Any ideas? Need any more info? Thanks! Specs of the main computer where problems started: Windows XP Asus M2N-VM DVI Motherboard AMD Athlon 64 X2 Dual Core 6000+ 4GB Ram |
Re: Unable to detect digi 002 AND 003, multiple systems.
Bad FW cable?
440Hz Yarra Valley, Melbourne, Australia ------------ Mac Pro 2,1 Dual Quad Core 3GHz 18 GB RAM OSX 10.9 Maverick's 3 x 1TB SATA 1 x 250 GB SATA (Seagate) PT 12.6.1 HD MC MIX RME UFX, Ferrofish A16 AE MIDAS Venice 320 -------------------- "The music business is a cruel and shallow money trench, a long plastic hallway where thieves and pimps run free, and good men die like dogs. There's also a negative side." Hunter S. Thompson |
Have tried multiple cables that are working with other firewire devices, but thanks!
Also I didn't hotswap any firewire cables and I've tried the firmware mode on the 003. |
What's the chipset in your firewire controller? What version of PT8? You should probably post a SANDRA report at this point. BTW - what do you mean by "the firmware mode on the 003"??
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Sorry, not sure what the mode is actually called but I meant holding Aux in 7/8 and Mute while powering on the 003. It's an LSI chipset, I can get a SANDRA report up tomorrow, thanks!
Pro Tool LE 8.0.4- Unable to detect digidesign hardware? | Bluejaye | Windows | 9 | 04-07-2013 08:24 AM |
Cannot Detect Digi I/O, Please Help | mbauer1 | Pro Tools TDM Systems (Mac) | 2 | 01-26-2013 12:00 PM |
Pro Tools unable to detect Mbox 2 | KangarooOne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-04-2013 06:49 PM |
Pro Tools LE 8.0.5 "Unable to Detect Digidesign Hardware" | MidimanZ72 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-29-2012 03:06 PM |
Unable to detect Digidesign hardware! (Digi 001) | junbug | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-31-2003 05:19 AM |
