Old 08-02-2018, 11:32 AM
quangaroo quangaroo is offline
Default Upgrade woes: Stop Button Lights Blue - Can't record/playback
Hi--
I recently updated from OX 10.8.5 & PT 12.4 to OS X 10.10.5 & PT 12.6.1. My hardware interface is a Digi 003. My old system was ROCK solid, but several issues (not audio related) required I update my OS.
Now I've got two things that occur with alarming frequency:
In the middle of a session, the stop button lights solid blue and the play button flashes green, and I'm unable to continue recording or playback until I quit PT, turn off the Digi 003 and restart both. I've seen others in the forum report the same, but no real solution.
The 2nd issue is more of an annoyance: upon launch I always get the query: "Do you want the application “Pro Tools.app” to accept incoming network connections?" even though I've gone to my Mac System Preferences and allowed the connection for PT in my Privacy settings.
I can download the update for PT 12.7 -- will that solve any of this? Or do I need another OSX upgrade as well? Or is there a simpler fix?
My Mac Hardware is:
Mac Pro Tower (Mid 2012)
3.33 GHz 6-Core Intel Xeon
32 GB of Memory
Graphics card: ATI Radeon HD 5770 1024 MB
SAMSUNG 1TB SSD Start-up drive
WD 4TB SATA Drive for PT sessions
Thank you!
Old 08-12-2018, 02:23 AM
StefB's Avatar
StefB StefB is offline
Default Re: Upgrade woes: Stop Button Lights Blue - Can't record/playback
Blue stop light - online waiting or timecode/midi?
Mac 8 Core 6,1 -Os 10.12.6 - 64 gb Ram - Protools 12.8 HDX - 8x8x8+8 ch DA Card - DCommand ES24 - Sync HD - Video Satelite (Symphony 8.9.1 on 4 Core Mac Pro Dustbin with AJA Kona 3g) Soundminer 4.5 Pro
Protools 12.8.0 Vanilla in 2 x Edit suites one with S3 and one with Mackie Control.
Mediacomposer 8.9.1 on AJA Kona 3g x 3 suites
Old 08-13-2018, 02:00 PM
I'm not using timecode/midi--but I have to admit I don't know what you mean by "online waiting" either :)
Old 11-12-2018, 09:34 AM
Just checking in: Any new info out there on this issue?
Old 11-13-2018, 05:58 PM
Hugh-H Hugh-H is offline
Hello,
The indicators you describe present when PT is put in chase mode and is waiting for timecode. Command-J does this, could you be pressing that by mistake?
Hugh
Old 11-24-2018, 08:36 AM
Yes, I definitely checked that--it's something else.
Old 11-24-2018, 09:54 AM
Both the issues in your original post have been discussed in DUC posts in the past, I know because I have posted fixes in some of those threads, you really should be searching for those... use Google search with “site: duc.avid.com” or “site:avid.com”, included in the search (without the double quotes). It is also worth searching the Avid support knowledge base if stuck, not sure if these items are there or not.
Old 11-24-2018, 10:07 AM
StefB's Avatar
Also - Trash your prefs!
Old 11-24-2018, 10:18 AM
Thank you! Is there a better technical term I should search for that more accurately describes this problem/issue?
Old 11-24-2018, 10:20 AM
Thank you--I'm looking into that now! I just want to make sure I know what I'm doing (and have my settings recorded) before I trash prefs! :)
No Playback - Stop button flashes Blue BurbankGuy Windows 6 05-31-2018 12:32 AM
can't play or record, stop button lights up robotboy Pro Tools 10 4 08-04-2014 08:34 PM
I push PLAY and Stop Button lights up Blue ??? Seafoam_Green Getting Started 3 07-06-2013 09:18 AM
Press PLAY and STOP button lights! ronlosangeles Pro Tools M-Powered (Win) 0 11-29-2011 10:19 AM
Hitting Play or Record, blue stop button lights up... delay Monty_python 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-06-2009 11:33 AM
