Old 12-06-2020, 11:10 PM
Sound Editing MunKee Sound Editing MunKee is offline
Default Pro Tools Editing Lag When Editing to Video
Hi Everyone!
Is anybody experiencing lag with the Pro Tools editing interface when editing to picture in the latest 2020.11 release?
I'm on Windows 10 Pro Build 18363. It's especially bad with 59.94 720p high bitrate prores proxy files. Not as bad with 29.97 prores proxy at a lower bitrate and/or resolution, but still difficult to work with. A couple quick specs on my PC worth noting are as follows:
CPU Intel Core i9 9900K
MoBo Gigabyte Designaire Z390 Rev 1.0
64 GB Ram
PCIE Storage 1TB HP EX950 SSD
EVGA nVidia GeForce GTX 1660 Black Edition Studio Driver v27.21.14.5730
Video is being output vid HDMI from a BlackMagic Intensity card
Audio goes out a UA Arrow Thunderbolt interface
I feel like this is related most likely to my GPU. I keep reading that Pro Tools on windows the preferred GPU of choice are nVidia Quadro GPUs although all that are specified are significantly out of date. Any suggestions on what to consider changing it out to? Any help would be appreciated! Many thanks!
Old 12-10-2020, 12:58 AM
mufi mufi is offline
Default Re: Pro Tools Editing Lag When Editing to Video
Are you using MXF container? I had this problem with MOV files in the latest releases. MXF works beautiful here.
Old 12-10-2020, 05:10 AM
lode lode is offline
Not sure if we are seeing the same, but:
I find the GUI to be lagging. I exclusively work with video, and almost always with .mov.
I found a noticable performance boost when I disabled Hyperthreading. But I still specifically the GUI to be slower than when working on much older macs.
t.ex. processing Dialogue Isolate (which is a fairly heavy Audio Suite) on a clip, the process will finish faster than on older macs, and appear on the timeline, while the processing window still hangs like a second afterwards. I can then even start to play while the processing window still overhangs the edit window a little while.
Other examples: Making fades and clipgaining feels sluggish.
Will look into mxf!
Newest Pro Tools on mac & pc.
Old 12-10-2020, 11:51 AM
I'm using a .mov container, what's a good windows program to transcode with?
Old 12-10-2020, 11:55 AM
Will look into mxf!
Definitely noticing the GUI being very slow with hires video. Playback also seems to take a lot longer to buffer from a stop to playing back. Audiosuite processing seems to not really be affected though. When I disable my video track, everything is really fast and responsive, however I need the video so I can work lol!
Old 12-10-2020, 03:57 PM
LAPostMix LAPostMix is offline
I'm getting a lot of gui lag when my video track is enabled as well. Disable video and editing is very snappy.
Mojave PT 2020.11 Native PCIE Artist Mix 2012 Mac Pro Kona LHI
Old 12-11-2020, 12:00 AM
lucas f. lucas f. is offline
Same here..about 3 second to stop and go back to play with video engine on...
Video engine off and everything goes back to normal...
I went the video slave way to be able to work...absolut shame...that cost me 15$ a month..
Feel like a joke comming from a video editing company..
Not a funny one though...
Envoyé de mon SM-G960F en utilisant Tapatalk
Old 12-12-2020, 05:45 PM
What's video slave? Thanks!
Old 12-13-2020, 01:35 AM
https://non-lethal-applications.com/.../video-slave-4
A video player that sync to pro tools by LTC.
Old 12-15-2020, 01:06 AM
That's what i am using
https://audiospot.audio/audiospot-creativetools
The tool is called DNxER. It has the option to transcode both to MOV and MXF.
Unfortunately they will cease to provide them for free in january.
The difference between mov and mxf is night and day, you shoud try it.
HTML code is On
Video *editing* in Pro Tools HD? TNM Pro Tools 2018 7 02-28-2018 01:17 PM
Editing Video with Pro Tools 12 Chouchou Pro Tools 12 4 10-30-2017 08:51 AM
Pro Tools Video Editing Application? Nathan W. Post - Surround - Video 12 07-01-2013 09:00 PM
Video editing within Pro Tools? cppmusic Pro Tools TDM Systems (Mac) 7 05-14-2009 05:09 AM
Pro Tools LE + video editing? rcook349 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-25-2005 04:11 PM
