sample rate mismatch problem?
Hey there folks. I recently recorded a session on my mbox 3. When I was done mixing, etc., I bounced to disk. The ol' higher pitch, faster rate problem happened. I'm pretty sure both my mbox 3 and the pro tools session was set to 48k. Any idea on how I can fix this?
Re: sample rate mismatch problem?
There's probably like a gazillion threads covering this on the DUC.. did you try a search?
Rail
Yea I did a google search. Perhaps, my search criteria wasn't the best choice. Out of the google search i did find a few that suggested the problem be sample rate mismatch on the interface and session. However, they are the same on mine... so I was lost from that. My clock is set to internal as well. Generally the threads ended there. So I am clueless.
While it would be easy to assume you had a clock mismatch with an outboard piece of digital gear, I can tell you that about 10 - 12 weeks ago people were posting here on the DUC about such issues and the word out was that there were acknowledged clock problems with some Mbox 3s. Contact tech support.
I appreciate the response you two. Thanks for the info Jimmy. I appreciate it.
Sample Rate Mismatch! (clock 44.1, PT 48) | RhodesB3 | Pro Tools TDM Systems (Mac) | 22 | 11-24-2015 12:17 PM |
Sample Rate Mismatch... How to export files as regions after problem. | Dizzi45Z | Pro Tools TDM Systems (Mac) | 2 | 04-24-2010 10:17 PM |
Big Ben / PT sample rate mismatch | zakco | Pro Tools TDM Systems (Mac) | 2 | 10-27-2007 06:36 PM |
Pro Tools LE Sample Rate Mismatch Nag | tcassel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-20-2007 12:51 PM |
sample rate mismatch with HD24 on whole session | BuddySchaub | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-10-2004 12:53 PM |
