Old 05-13-2009, 12:00 PM
RhodesB3
Guest
Posts: n/a
Question Sample Rate Mismatch! (clock 44.1, PT 48)
How does one fix this issue:
I recorded a session where pro tools was set to 48k and the clock was set to 44.1. When I bounce, the files play at the wrong speed. My assessment is that the files are actually at 44.1, but pro tools thinks they are 48. How do you rename the file headers so that they are seen as 44.1?
What do you do??? (other than always check the big ben... I think it used to give me an error message?)
Old 05-13-2009, 12:13 PM
MoritzRock MoritzRock is offline
Default Re: Sample Rate Mismatch! (clock 44.1, PT 48)
Originally Posted by RhodesB3 View Post
Try importing it into another session set at 44.1, not sure it will work you might get a slower playback if so try to uncheck the convert SR box when you import it. not sure you can BTW. never been in the situation.
I am not sure what you mean by when i bounce, are you bouncing at a different SR? is Playback ok?
Mo
Old 05-13-2009, 12:24 PM
RhodesB3
Guest
Posts: n/a
Thanks Mo,
I've tried that, and it doesn't work. If I create a session at 44.1, and import the files, pt thinks that its at 48, so it wants to do a src. If there is a way to rename the header in the file, that would be the thing to do. but how??
Old 05-13-2009, 12:37 PM
rafukyo rafukyo is offline
HI
I think you will have to pitch shift and time exp/comp to fix it.
Rafi
Old 05-13-2009, 01:05 PM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is online now
Create a new session at the correct sample rate (44.1k), use 'Import Session Data' and import the misclocked session tracks. Choose not to do an SRC on the audio.
Marc Schellekens
Delta Music Belgium - Dolby Atmos Music Studio
https://www.deltamusic.be
Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins
Old 05-13-2009, 01:07 PM
hummerZ hummerZ is offline
Soundhack can alter the SR flag in the header, if you're on a mac.
http://music.ucsd.edu/~tre/soft//SH896.zip
Old 05-13-2009, 01:18 PM
ABrooks ABrooks is offline
I did this once and I had to adjust the speed. 8% is the difference between 44.1 and 48k. So that's what I did and it worked, but I only had to do it on a VT and not instrumentation thank goodness.
But I know there's a way to make DP or Logic think that a session is a different sample rate from ProTools to correct the issue. I didn't do that personally but a friend of mine had to on some stuff someone else sent him.
Old 05-13-2009, 01:35 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
If you have another rig, play out from one and record on the other.
This is the safest way.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 05-13-2009, 01:36 PM
This is the correct method.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 05-13-2009, 11:08 PM
Dizzi45Z Dizzi45Z is offline
+1. I ran into the exact same problem and a year ago and fixed it with this method as well. It really is the fastest and easiest way to fix the problem.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
sample rate mismatch problem? Kevin_28 Pro Tools 9 4 12-22-2010 11:18 PM
Sample Rate Mismatch... How to export files as regions after problem. Dizzi45Z Pro Tools TDM Systems (Mac) 2 04-24-2010 10:17 PM
Big Ben / PT sample rate mismatch zakco Pro Tools TDM Systems (Mac) 2 10-27-2007 06:36 PM
Pro Tools LE Sample Rate Mismatch Nag tcassel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-20-2007 12:51 PM
sample rate mismatch with HD24 on whole session BuddySchaub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-10-2004 12:53 PM
