Old 01-22-2021, 06:56 PM
Default Re: What is the Hybrid Engine?
Originally Posted by loopzilla2 View Post
Under about 20 tracks there isn't much difference. Mixes null pretty well except for verbs and real-time-generated effects. After 24 tracks (or so) all bets are off.
Have you tested that mixes with greater than 20 tracks null over multiple passes with the same mix engine? i.e. there's not a plugin that is non-deterministic in the path? You've got me curious to test now.
https://lukehoward.com/
Old 04-18-2021, 09:24 AM
carlosdiasjr carlosdiasjr is offline
Hopefully it has some kind of wrapper for native AAX to work as AAX DSP as well or this still is not worth going to HDX.
Old 04-18-2021, 09:47 AM
HTDM was a bad idea back in the day, but at that time it was needed. Now it does not matter if you throw AAX-native or AAX-DSP to the mixer, no problem. RTAS/TDM did not live so well together in the beginning of native days.
Old 04-18-2021, 12:16 PM
Will Russell's Avatar
Will Russell Will Russell is offline
It seems most likely to me that it will work the same as Carbon. You will need an AAX-DSP version of the plugin in order to track with the low latency DSP path.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 04-18-2021, 04:25 PM
arche3's Avatar
arche3 arche3 is offline
Isn't Carbon all messed up right now? I'd rather stay pure hdx3. Or add more hdx cards in the 7.1 mac pro. I think it will work with 6.
Sent from my SM-G986U using Tapatalk
Old 04-18-2021, 04:43 PM
I haven't heard anything about Carbon being all messed up but then again I don't use it nor do I actively seek information on it.
The potential of using the hybrid engine with HDX is huge to me. No need for multiple cards just to achieve a higher track count because you'll be using the CPU to power the mixer which resolves the voice count limitation of the DSP on the HDX card. I think hybrid coming to HDX is going to be a BFD.
But hell, if you can afford a 7.1 Mac Pro and six HDX cards then go for it! More power to ya!
Will Russell
Old 04-18-2021, 05:00 PM
K Roche's Avatar
K Roche K Roche is offline
Thanks for the replies.
So we will run the mix engine natively now? I don't like how the native mix engine sounds compared to the HDX mix engine. Or at least I didn't the last time I tested it. Have things changed?
Yeah, I read the Carbon stuff and saw the coming-soon blurb. So there's a button to change a Native plugin to DSP while the rest of whatever plugins use Native - or DSP. But we've always been able to do that. So confused why I should want this? I mean, time will tell for sure.
Maybe it's to offload the mixing chores to the native CPU so the card can just run plugins?
Don't know about this sound difference in mix engine you are taking about (But I then have never had HDX)
But I can answer some of the above.
Before "Hybrid" in an HDX system you could run native plugins and DSP plugins in the same session,,,, BUT they were all running on the the HDX mixer. The native plugs were in native mode, DSP plugs in DSP mode BUT all were running on the HDX Mixer chips.
With Hybrid only the plugins running in DSP mode (on tracks in DSP mode) are running on the HDX mixer chips . Any plugs on tracks still in "native mode" are running on the computer CPU (not the HDX chips) And native only plugs that are on tracks in DSP mode are bypassed OR you can put that track in DSP Safe which takes the track out of DSP and then any plugs are then running in Native mode
Here is a video I did about Carbon but explains running Hybrid
https://youtu.be/YFhujEU8X30
System :
Enjoy the Journey
.... Kev...
Old 04-18-2021, 09:00 PM
MixerGuy MixerGuy is offline
Isn't Carbon all messed up right now? ......(snip)
no, not at all.
Carbon is super solid, as is the Hybrid Mix engine with it.
Old 04-18-2021, 10:10 PM
I've been reading about the new Hybrid Engine coming for HDX users. One of its main features seems to be the ability to switch a plugin from DSP to Native and back again. Don't HDX users already have that? I've used the feature for years.
I'm confused about what the Hybrid Engine brings to the table. Can anyone share more info?
tons of info here.
this article is not paywalled currently.
https://www.soundonsound.com/reviews...o-tools-carbon
Old 04-18-2021, 11:09 PM
matchmix matchmix is offline
It's probably Avid's workaround for expanding HDX Voice count beyond 256 Voices
upcoming Hybrid Engine HDX Option? DetroitT Pro Tools HDX & HD Native Systems (Mac) 16 03-01-2021 04:34 PM
Upgrading from Hybrid 1 to Hybrid 3? tuomiopäivä Virtual Instruments 2 01-11-2016 12:01 AM
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 11:52 AM
Playback Engine>Current Engine issue Hunterkiss macOS 0 06-28-2013 01:14 PM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
