Offline bounce means trouble...
Hi Guys,
Here's my findings with offline bounce: Whenever I do an offline bounce, when the bounce is complete, Protools starts behaving buggy. In most cases I get the 'stop-play' button issue that results in the fact that I can no longer play audio on the timeline. (after pressing play protools immediately stops) The only way to cure this issue is a restart of Protools. After an offline bounce it's impossible to shut down protools the proper way (it freezes) If there is a fade at the end of the region, the resulting offline bounce always has a small portion of audio after the fade... The volume of bounced files sometimes randomly changes (whole file) Like many of you offline bounce was one of the major reasons for a fast upgrade to v11, but for me, sadly, it seems unusable...
Asrock Fatal1ty X299 - i9 7960X- 128GB DDR4 - 3x m2 samsung evo 2TB pciex4 SSD - Geforce 3070 ti - Win11 x64 - PT HDX - HD Omni - HD I/O |
Re: Offline bounce means trouble...
It might help us if you give the following info:
session sample rate and bit depth Bounce settings Playback buffer computer specs interface Help us Help You - READ THIS Before Posting!
Never hit the Play/stop on my HDX/Omni rig.
Nor a small portion of audio after the fade. My selected time , √ import after bounce (Off-line√) and position at selected match. As mentioned above (albee1952) also include versions otherwise is all guessing....
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
ok here's the specs of the session (just an example, I've experienced the problem in other sessions woith possible different settings as well)
session is 32 bit float, 88.2 khz playback buffer is 1024 samples, 128 voices (2gb cache) session uses a few plugins from waves (on tracks) and izotope ozone 5 (on master bus) system see signature... convertor is omni offline bounce settings: bouncing from audio 1-2 (stereo monitor) wav 16 bit 44.1 interleaved ...
Asrock Fatal1ty X299 - i9 7960X- 128GB DDR4 - 3x m2 samsung evo 2TB pciex4 SSD - Geforce 3070 ti - Win11 x64 - PT HDX - HD Omni - HD I/O Last edited by breakie; 10-10-2013 at 06:22 AM. Reason: more info |
I can not believe I'm the only one experiencing this problem...anyone else???
I have had similar since adding some new plug-ins.
Ozone 5 regular is one that i've stopped using temporarily to see. Been offline bouncing with no crashes. However I added Recabinet and it began again. Yet on restart-of-app it does not happen. I'm leaning more towards the auto-backup interval failing. After crashing go to your session backup folder and check the time intervals. Mine a always off (Pref setting for every 2 min, after crash there is 3-4 min from crash and previous BU. Thanks for bringing this up. T PS I work at 32bit 44.1
My PT 11 crashes when trying to do an offline bounce of
4 mono audiotracks 1 stereo Ircam Flux reverb aux channel 1 stereo master track with Channel Strip, Pro Compressor and Fab Filter Pro-L. 3:30 of music cached from internal SATA drive in slot 2 96KHz/24bit BWF _________________________________ PT HD 11.0.2 Mac Pro 4,1 8-core dual 2.26, 24GB Mac OS 10.8.4 MBox Pro (3rd gen) Last edited by soundgott; 10-24-2013 at 11:59 AM. |
Just found that Flux Ircam Verb is the culprit.
With that track deactivated the offline bounce works fine. Shame... |
I just got caught with the offline bounce fade at end of bounce bug.. Aaaargh!
Between that and the laggy video playback when working to picture, I'll have to stick with 10HD a while longer me thinks.
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 |
Just off-line bounced a 5.1 mix (3 mono tracks with unveil and RX3 dialogue-denoiser and channel-strip, a stereo music and 2 revibes
). Result was half a frame (24.00fps based) early throughout. I guess ADC has issues in off-line bounce. Interestingly a bounce made with the same template but without unveil and RX3 is sync so maybe delay reporting issues with certain plugins. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Offline bounce bug ? | deardaddy | Pro Tools 11 | 20 | 12-28-2016 02:43 PM |
offline bounce different than realtime bounce | grant howarth | Pro Tools 11 | 8 | 12-08-2013 09:29 PM |
Mac OS X 10.4.10 with PT LE 7.1.1 means trouble??? | matte81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 07-23-2007 04:29 PM |
Offline bounce | spyfly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-21-2007 12:50 PM |
what means squeeze in the bounce window??? | floplight | Tips & Tricks | 1 | 10-15-2003 11:39 AM |
