Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Duet & Pro Tools | Quartet
Old 04-25-2019, 06:39 PM
davision davision is offline
Default Pro Tools 2018 and Apogee Element help
I recorded tracks using a Focusrite Clarett 4pre thunderbolt on Pro Tools last week (using a Mac high Sierra) and then changed to an Apogee Element and have been recording with this since but now I want to go back into the Focusrite sessions with my Apogee but all the Clarett recorded tracks don’t have input or outputs and are silent. When I check the I/O settings there isn’t anything there, anyone able to assist with this (probably a simple fix) - confirming my Element is installed and recording perfectly, no problem there it’s when I try and import or open tracks/a session recorded with Clarett is where the problem is.
Old 04-25-2019, 07:00 PM
Default Re: Pro Tools 2018 and Apogee Element help
Make sure the correct playback engine is selected.
“Default the IO” and then select the correct inputs and output
You default the IO by going to each of Setup>IO>{input,output,bus} pages, selecting all the IO paths and click Delete, then click Default, repeat for each page.
Old 04-25-2019, 09:20 PM
Thanks - it wasn’t that - Apogee simply name their inputs Analog, Optic etc. instead of Apogee Analog 1 - I would’ve found it straight away, all sorted now thanks
Pro Tools 2018.3 / 2018.4 crashing when switching window configurations matthewmkb macOS 0 06-27-2018 06:33 AM
apogee rosetta and protools 2018 joeydego Pro Tools 2018 12 02-12-2018 09:06 AM
Any Element Users?? simon.a.billington Virtual Instruments 0 11-08-2015 10:47 PM
Waves Element Picophone Buy & Sell 0 11-20-2013 08:03 PM
TC Powercore Element vs UAD 1 hgen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-29-2004 03:04 AM
