#21
Re: Digi 002r and OSX Yosemite working
So has anyone gotten the 002 working on El Capitan? Haven't been to my studio to test yet.
Macbook Pro 2.2GHz (late 2011 model), 16GB RAM, OSX 10.7.5 |
#22
so is it still working? do you get sample rate errors in Logic Pro X or latency issues? |
#23
you won't believe this.. I just updated to El Capitan.. and my 002r wotks fine :)
#24
Which drivers did you use?
#25
the same driver I used for Yosemite.. the 003 driver (with no guarantee/not tested with 002) .. I haven't touched anything driver wise.. just installed El Capitan, opened PT 12.3.1.. and it works! .. but as with Yosemite, I need to turn the 002 on before i switch on my com.. but that's nothing new :)
#26
What version number? If you're using 11.x, you need to check one thing.....when your 002 is plugged in, check kernel_task under CPU tab in activity monitor. Is it spiking? If so, that could lead to probs later down the road. Only driver that didn't spike kernel_task was 10.3.3, but not sure if that will work in El Capitan. If you try it, make sure you delete all previous Digi/Avid drivers and files.
#27
I'm pretty shure it's the 11.1.3 .. I'll give it a try and see... thanx for the info Simon
#28
well.. I went down another road, and just ordered a saffire 56.. better be on the safe side for now
#29
For those who still wish to use the 002/r on El Capitan, I was able to get my 002r working using the 10.3.3 drivers. Initial testing looks good. Haven't put it they a hard test yet (20+ tracks). So far it runs great on Ableton and Logic (can't say anything for Pro Tools since I don't use it anymore). Just make sure to remove DigiDioMidiDriver.plugin file from the Midi Drivers folder (located in HD>Library>Audio>Midi Drivers) as that has caused problems in the past.
#30
This post saved me some money. The 10.3.3 worked on El Capitan, with latest Logic X 10.2.1 and 002Rack.
11.0 work as well. No tweaking or removing of the DigiDioMidiDriver file. Very stable. Does not have Pro Tools to test it. I did not even try it before. Installed a ML partition instead. So thank's for this!
https://www.facebook.com/petermartinssongroup/ |
OSX Yosemite and Digi 002R | guitarplaya1423 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-04-2014 01:30 PM |
MBOX 3 mini not working on Yosemite | Raden Agung | FireWire & USB Audio Interfaces (Mac) | 2 | 11-20-2014 09:58 AM |
DIGI-002R S/PDIF not working | socko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 12-05-2010 09:44 PM |
Sia Smaart and Digi 002r not working!?! | Andi R | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 09-21-2005 08:03 AM |
Digi: 002R Clicking but not working | JKD99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 07-30-2003 08:21 PM |
