Pro Tools quit unexpected
Hi there,
After installing Pro Tools 10, it gives an error message. " Pro Tools quit unexpectedly " Why is this happening ? Thanks, |
Re: Pro Tools quit unexpected
Check what plugin is displayed just before it crashes and move that plugin from your plugin folder to the not used plugins folder.
It crashes 3-4 seconds after it scans everything ... I don't think it's a plugin issue.
I have had the same error message numerous times when using the Strike plug in. I have to start over each time after the crash.
I am not using Strike ... |
bump
This is apparently cross platform. I had this happen a couple times on windows last night - 1 time without even the message, just a system freeze. Happned using the channel strip while recording
How did you fix it ?
I stopped recording with the channel strip active lol
I didn't have the time or patience to find a permanent solution last night, was in the middle of a session. I'm going to do a laundry list of tweaks and throw out some old outdated plugs that should have been gone awhile back and see if that does anything. |
I understand your situation, but mine is not even running.
It gives me an error message after it scans everything. |
Pro Tools quit unexpected when opening... | Patill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-30-2011 03:12 AM |
The application Pro Tools LE 7.1.1 quit unexpected | neilshah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-25-2007 10:34 PM |
10.3.9 LE6 unexpected quit | creativebond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-31-2005 12:02 AM |
Unexpected Quit with Pro Tools 6.7! Need HELP | js54 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-29-2004 03:24 PM |
Unexpected quit | beholder74 | Pro Tools TDM Systems (Mac) | 1 | 11-25-2004 11:30 PM |
