Old 10-15-2017, 07:16 AM
alexthemusicbloke alexthemusicbloke is offline
Default S3 + Mackie Control or HUI
Hey All,
Loving my S3 in ProTools - so glad I went for this over the alternatives on the market as it's really well implemented in ProTools.
It'd be GREAT however, to be able to use it with some of my other software. I regularly flick into RME TotalMix and occasionally Reaper. I've enabled HUI and Mackie Control in the EuCon app but I can't get it to play ball with the S3 at all.
Is this possible? If so, what am I missing?
Thanks!
Alex
Old 10-15-2017, 04:45 PM
mattrixx mattrixx is offline
Default Re: S3 + Mackie Control or HUI
I have definitely been able to control Totalmix before.... and just tried again. Mmmm, I cannot get it to work again either.
I have also used it with Ableton Live 9 and will check that out later on today.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 10-17-2017, 05:58 AM
So it's certainly do-able? That's good to hear.
I love my S3 but I'm finding it a little restrictive to only be able to use it in ProTools at the moment, especially considering the price.
Any help here would be greatly appreciated, if anyone has it to offer.
Thanks!
Alex
Old 10-17-2017, 12:19 PM
made made is offline
Reaper supports Eucon. Works very well with S3.
https://forum.cockos.com/showthread.php?t=122509
The last time I tried Mackie Protocol with S3 it was a nightmare...
But that was in 2015 when S3 was introduced.
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78)
LIO-8
BlackmagicDesign UltraMonitor3G
Reaper 6.66, Fireface UCX
MacbookPro M1Pro PTHD2021.12 MacOS12.1
MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB
Old 10-17-2017, 01:27 PM
Unfortunately the EuCon plugin for Reaper is extremely buggy, with both the S3 and the Artist series.
The surfaces work fine, but the whole DAW grinds to a halt and crashes regularly. I've tried it on numerous setups and always had the same issue.
For example, deleting a track in Reaper gives you a ~10-15 second lock-up and the occasional complete crash.
Mackie Control support would be the best option I think!
Old 11-25-2018, 02:59 AM
Sonogents Sonogents is offline
I tried using my S3 for Audiokinetic Wwise.
In MackieControl mode, I get following knobs and faders to work for each channel: fader, lower encoder, sel, solo, mute, "ín" (next to the lower encoder.)
However, only faders 1 and 9 respond to Wwise and they seem to respond to respond to the last active fader in the sofware of their group, i.e. if I have 11 faders in Wwise, fader 1 of the S3 would show the value of fader 8 in Wwise; fader 9 on the s3 would match fader 11 of Wwise, as if the midi channel is being ignored.
Also, faders and encoders are useless as they don't send out any linear values but raher some seemingly random values at the edges of the range.
HUI mode doesn't work at all. No buttons, faders or encoders are recognized and I get BSOD's all the time.
My AVID Transport isn't recognised at all, although it shows Wwise as the active app on it's display.
The software works perfectly fine with my digi003, so it's not an issue on the Wwise part.
Any thoughts or plans to make this work as advertised on the Avid side?
www.sonogents.com
Old 11-27-2018, 08:06 AM
Halfmoon Halfmoon is offline
I haven't used Wwise but did have a similar problem at first w/ Ableton. With MackieControl and the S3, check to make sure you've chosen "MackineControl" for the first 8 faders and then "MackieControlXT" for the 2nd (9-16).
To see how this is done in Ableton check out the most recent EUCON Application Setup guide (should be in your Avid account, and is also available via the Knowledge Base).
M
Old 11-28-2018, 12:44 AM
yoerik yoerik is offline
Hi Halfmoon,
thanks for the tip! the issue I have using MackieControl protocol is that the response of the faders and knobs doesn't seem to be linear or continuous. Only at the lower end of the fader range and somewhere near the top, seemingly quite random values are being recognized.
In Wwise, I've got a digi003 working (midi mode) as well as an old Roland controller in HUI mode, so I am assuming the issue (for wwise) is with the Mackie protocol.
Old 01-29-2019, 02:14 PM
beatlogik beatlogik is offline
M
@Halfmoon Have you had good results with this? I still have not been able to get the S3 operating in Ableton 10 so I gave up.
Old 01-30-2019, 07:48 AM
EddieJones's Avatar
I think we have found an issue where if you have installed a fresh install of EUCON recently (not upgrading from an old version) Mackie control fails. We are looking at fixing this in the next release. In the meantime I think I have a workaround. Install v3.6.1 first and then install 18.3 over it.
MAC 3.6.1
PC 3.6.1
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
Digi 003 Control Surface Mackie Control Mode ctmusicman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-23-2008 07:23 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
Can the Mackie Control extender work w/o Mackie Control? fingerz88d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-03-2003 08:52 AM
a note from Mackie about the Mackie control remote Pro Tools TDM Systems (Mac) 100 11-02-2002 12:25 AM
