Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 03-04-2020, 08:12 PM
blackbird99 blackbird99 is offline
Default Fast Track Ultra Control Panel Disable Host Control??
Hi all
I'm using a Fast Track Ultra as a live sound interface and recording with a DAW at the same time.
With the Windows driver you have the option to "Disable Host Control".
With the Mac driver you don't? I can't find it. Anyone run into this?
Old 03-05-2020, 03:03 PM
Default Re: Fast Track Ultra Control Panel Disable Host Control??
Well. There is answer. On the Mac, you don't need to disable host control it seems.
The Fast Track can be used as a plain ol interface and mixer. Just use the control panel to set your mix(s) and go. Works. If you try to record at the same time with Windows and Pro Tools, Pro Tools shuts down the sends in the Fastrack. You can get software returns from the DAW but they are lagged. You have to disable Host Control and then it works.
With a Mac and Pro Tools it works the way you think it should. You can send inputs to the outputs and record.
Setting output levels in Fast Track Ultra control panel. Gus Audio FireWire & USB Audio Interfaces (Win) 1 11-30-2016 10:44 PM
Fast Track Ultra 8R - Host Control not working MadDogRunner FireWire & USB Audio Interfaces (Win) 2 11-01-2013 06:25 AM
Fast Track c600 Control Panel Display Issue buchel Digidesign Hardware & Software 0 11-23-2012 04:14 PM
Fast Track Ultra: No Control Panel Dippy Pro Tools M-Powered (Win) 0 11-01-2012 04:27 AM
