Old 12-21-2006, 08:13 PM
tomcat tomcat is offline
Default missing audio files are actually not missing
Often when I open a session now in 7.2, when it reports missing audio files, i choose manual relinking, and when the relink window opens, the files are all there. I choose "find links" and it grabs them instantly. the point is, why does the session say they are missing when they are sitting there in the relink window, complete with waveforms, before I tell it to search?
a little scary in this era of corruption.
tom
www.tompaul.com
Old 12-22-2006, 07:08 PM
Default Re: missing audio files are actually not missing
Are you using v7.2cs1 or cs2?
Old 12-22-2006, 09:15 PM
cs2
tom
www.tompaul.com
Old 12-24-2006, 02:25 PM
TommyT TommyT is offline
I had this problem... I got a bunch of WAVE files from a client that were printed in Logic.. and every time i booted my session it would always not find these particular files.. (also the Time stamps would not work...)
the rest were fine.. I also noticed that after each time i manually re-linked them the date modified would be updated... I even saved as copy (WAVE) with audio and PT still wouldn't find them...
So I discovered that if I saved as Copy with audio and changed to AIFF then saved as with audio again back to Wave.. PT could now find them every time... and all was good from then on....
Obviously there was something in those Wave files... some reasource that PT could not repair.. yet at the same time it did not recognise the problem as being a problem...
Oh YA.. I was using 7.2 latest G5 Quad PCI-e HD 10.4.8.. and updated to 7.3 just to see if it would help.. But the update had no effect
Hope this Helps .. Cheers Tom...
Missing fade files, missing audio in resaved sesssions drygruo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-14-2010 04:56 PM
All Sessions using SDII files are missing all audio files and won't relink bigmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-18-2009 12:54 PM
Pro tools says Files Missing but they're NOT missing.... nealobrien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2008 06:09 PM
missing audio files anurag 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-02-2004 05:31 AM
Missing Fade files become missing audio files? Tim R. Pro Tools TDM Systems (Mac) 11 06-21-2004 09:48 AM
