Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 04-08-2021, 04:18 AM
uptheoctave uptheoctave is offline
Default Re: HD driver MTRX studio
Originally Posted by originalscottyg View Post
Are you using a MTRX or MTRX Studio connected to the HDX card for monitoring? How do you run the native interface back into the MTRX for monitoring?
I have the MTRX but the process is pretty much the same for the Studio.
My studio is pretty complex as I have a couple of native interfaces.
1. Focusrite Red 16 Line
2. Focusrite Rednet PCIER
3. UA Apollo X8
The Red 16 Line and Rednet PCIER card simple serve their native audio up to the Dante network and are monitored in Dadman.
The Apollo X8 presented a challenge.
Did I really want to chew up a stereo pair of outputs on the MTRX in order to monitor the signal?
No, I did not.
So I bought a 2 input Audinate Dante adapter and it takes the stereo output from the UA, which can be operating at any sample rate that I like and serves it to the Dante network at 48khz.
I found myself using the Apollo at various sample rates and having it switch freely to whatever sample rate it needs to but convert to the Dante network which never really diverges from 48khz to be the best approach.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 04-08-2021, 09:43 AM
basehead617 basehead617 is online now
The fact that the accepted way of having native audio work with MTRX is dante virtual soundcard is absurd.. sounds like one of those windows workarounds from the bad old days of iffy jerry rigging things together..
Old 04-08-2021, 11:13 AM
As far as I know, that's how Avid HD hardware (HDX, HD Native, and I think even TDM) has always worked. There was never a multi client driver, that I can recall, that would let you pipe system audio through that hardware while running Pro Tools. People have always used workarounds for this purpose, like sending the optical output of their Macs to an optical input on their 192/HD|IOs. You can use MTRX and MTRX Studio via HDX/HD Native as a playback device for system sound while Pro Tools isn't running, just like you can with any other digilink converters.
Dante is also just one way to do it with MTRX/Studio. You can also send system audio out analog, connect it to some AD's on the MTRX, and use those as a monitor source in DADman.
Scott Gatteño
Old 04-08-2021, 02:36 PM
It would be fine if the MTRX could SRC those DVS channels.
But it can't so it doesn't really work, I agree.
The way I think of it is the MTRX is two products in one (at least).
The monitor controller side of things is brilliant.
I just use the Focusrite PCIER card for most of my nature audio, it connected into the MTRX monitor section and does its thing.
I am using HDX and Pro Tools less and less these days, Nuendo with the PCIER card + MTRX as a monitor controller is really excellent, although I could have saved myself a load of money by going for the DAD AX32.
James Richmond
Affiliate Links:
Old 04-08-2021, 03:08 PM
LukeHoward LukeHoward is offline
Or if DVS could follow the sample rate of the MTRX, as then you could leave CoreAudio to SRC. Expensive alternative is the Dante card for the MTRX which I believe includes a SRC.
https://lukehoward.com/
  #16
Old 04-09-2021, 12:30 PM
I have that card but it is globally changeable, not channel by channel, so you'd be spending £2k for a 128 channels of Dante to SRC just for native audio.
James Richmond
Affiliate Links:
  #17
Old 04-12-2021, 07:25 AM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
Thats why I didnt go the Dante route, I bought an RME AES/EBU pcie-card for my macpro which looks at the incomming signal from the Mtrx and switches the word-clock accordingly (see picture).
So my macpro core audio goes from RME-card to Mtrx always in the same sample-rate as the Mtrx is operating in. (which in my case always looks at PT primary port)
Works like a charm.
So for Soundworks UK who started this thread, because of the missing AES/EBU ports on the Mtrx-studio, I would try one of these RME pcie HDSPe cards: RayDAT or AIO-pro or the 9652, cards which all have the Adat-protocol, and use this as core-audio I/O.
File Type: jpg Schermafbeelding 2021-04-12 om 17.25.12.jpg (40.0 KB, 0 views)
PT Ultimate 2024.03.0, Avid S1, Eucon 2023.11
16" MacBookPro (2023) M2 Max 12-core, 64gb Ram, 1Tb SSD, OSX 14.4.1
MTRX v.2.4.2.2 + dante card + madi baseunit + optical SFP 1300nm
MTRX-II v.1.0.5.2 + TB3 + 1x AD mic 8ch + 1x DA 8ch
MOM v.1.0.1.4 by DAD
Genelec 1237A Sam, Avantone active mixcubes
LA2a (1968), 1073 pre/eq, Neve RNHP, Wacom Intuos Pro
Furman P1400 AR E Power conditioner
Live-rack:
1x HD Native TB, 4x 192 I/O (64ch AD)
8x Yamaha HA-8 micpre, Rosendahl mif4,
Genelec 1031A, Presonus Monitor Station
MTRX Studio with HD I/O nedd Pro Tools | MTRX & MTRX Studio 37 07-04-2023 04:58 PM
MTRX Studio Philharmonic7 Pro Tools HDX & HD Native Systems (Win) 15 08-23-2021 03:16 PM
MTRX Studio i/o Cheesehead Post - Surround - Video 9 02-21-2021 08:17 AM
MTRX Studio - AVB [email protected] Pro Tools | MTRX & MTRX Studio 3 02-03-2021 02:32 AM
MTRX Studio - No AES?! Ryan Young Pro Tools | MTRX & MTRX Studio 23 02-23-2020 02:13 PM
