Old 08-01-2012, 02:48 AM
sajack23 sajack23 is offline
Default Can't Change Buffer Size?
Hey guys I'm having an issue with changing the buffer size. When I go to setup, playback engine, H/W Buffer Size I get the option for 512 samples, but when I click it there's no other options for samples. It only gives me 512 samples....is there a reason it's doing this, and if so what do I need to do so I can change the samples/buffer size?
Here's everything I'm using and running:
Windows 7 64-Bit SP1 Computer, Pro Tools 10, Focusrite Saffire 6 USB Interface, KRK RPG2 Rokit 8 Monitors, M-Audio Venom, Native Instruments Maschine, Kontakt 5, Reaktor 5, Guitar Rig 5.
I appreciate it if you could help me, thanks guys!
Old 08-01-2012, 04:43 AM
Raggi Raggi is offline
Default Re: Can't Change Buffer Size?
HI.
Change the buffer size using the MixControl software to change the buffer size.
Old 08-01-2012, 06:41 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default
I think u have to quit pro tools to change that - to b honest I leave mine at 512 and just change the one inside PT - I never mess with the one on the mix control
Daniel
Old 08-01-2012, 02:54 PM
Yeah I've been using the mix knob on my interface, and when I do that the delay goes away. Except, the downfall is when I do that, I can't hear the other tracks while I'm recording, and I can't hear any plug-in/effect I put on a guitar as well. Is that what mix control is? I'm fairly new with this.
Old 08-02-2012, 03:14 PM
chris focusrite chris focusrite is offline
Focusrite
The buffer size is changed from the Focusrite control panel. This can be access from your Start menu in the Focusrite folder or, via the Control Panel button in Pro Tools' hardware setup dialog.
Chris
Focusrite Support
Old 08-05-2012, 05:29 PM
Ah thank you! Much better now
Cant change buffer size shea Pro Tools 11 0 01-16-2014 11:38 AM
So, When change H/W Buffer Size...... gonsdeejay Pro Tools 11 0 07-29-2013 09:12 AM
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 11:20 AM
PT9 / Buffer size won't change narapo Windows 3 08-15-2011 02:59 PM
Can't change buffer size zkarssli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-26-2010 06:49 PM
