can't open 9.0.3 "selected ASIO audio device could not be initialized"
I have my 003 plugged in and drivers installed but I still get this message. Any ideas?
SiSoftware Sandra Computer Model : Toshiba Satellite A505 Workgroup : WORKGROUP Host Name : TimMoore-PC User : Tim Moore Processor Model : Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz Speed : 2.13GHz Cores per Processor : 2 Unit(s) Threads per Core : 2 Unit(s) Type : Mobile, Dual-Core Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 Cache : 2x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 Cache : 3MB, ECC, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 16 threads sharing Computer Mainboard : Toshiba Portable PC BIOS : INSYDE 1.40 08/31/2010 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.8GB DDR3 SO-DIMM Chipset Model : Toshiba Core (Arrandale) Mobile DRAM Controller Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Total Memory : 4GB DDR3 SO-DIMM Shared Memory : 34MB Channels : 2 Memory Bus Speed : 2x 533MHz (1GHz) Memory Module(s) Memory Module : Hynix (Hyundai) HMT125S6BFR8C-G7 2GB DDR3 SO-DIMM PC3-8500S DDR3-1066 (7-7-7-20 4-27-8-4) Memory Module : Hynix (Hyundai) HMT125S6BFR8C-G7 2GB DDR3 SO-DIMM PC3-8500S DDR3-1066 (7-7-7-20 4-27-8-4) Video System Video Adapter : Intel(R) HD Graphics (12 SM4.0 667MHz Turbo, 66MB DDR3 1GHz 128-bit, Integrated Graphics) Graphics Processor Storage Devices Hitachi HTS545050B9A300 (500.1GB, SATA300, 2.5", 5400rpm, 7MB Cache) : 466GB (C:) TSSTcorp CDDVDW TS-L633Y (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices TI103272W0D (C:) : 454GB (NTFS) @ Hitachi HTS545050B9A300 (500.1GB, SATA300, 2.5", 5400rpm, 7MB Cache) System : 1GB (NTFS) Optical Drive (D:) : N/A @ TSSTcorp CDDVDW TS-L633Y (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Toshiba HM55 LPC Interface Controller LPC Legacy Controller 1 : Winbond WPCE775LA Audio Device : Toshiba P55/PM55/3400 High Definition Audio Audio Codec : Realtek Semi High Definition Audio Disk Controller : Toshiba P55/PM55/3400 4 port SATA AHCI Controller Disk Controller : Toshiba PCIe SD/MMC Host Controller USB Controller 1 : Toshiba P55/PM55/3400 USB2 Enhanced Host Controller USB Controller 2 : Toshiba P55/PM55/3400 USB2 Enhanced Host Controller FireWire/1394 Controller 1 : 22136 DC-1394 PCIe SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Canon Inkjet MP510 Printer (600x600, USB, Colour) Printer : HP Deskjet D4100 series (600x600, USB, Colour) Network Services Network Adapter : Realtek PCIe FE Family Controller (Ethernet) Wireless Adapter : Realtek RTL8191SE Wireless LAN 802.11n PCI-E NIC (802.11g (ERP), TKIP, 54Mbps) Power Management Mains (AC) Line Status : Off-Line Battery No 1 : 61% Operating System Windows System : Microsoft Windows 7 Home 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 4.2 |
Re: can't open 9.0.3 "selected ASIO audio device could not be initialized"
Could be a problem with your firewire controller - either an incompatible chipset or driver. Try a different firewire driver such as the legacy one and see if that helps. Not sure what your firewire chipset is from the Sandra but a TI is what you need.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Try holding dow the "N" key when starting up Pro Tools. You should be able to select the 003 that way.
Cheers,
"The selected ASIO audio device could not be initialized..." error | PResin | Windows | 12 | 06-07-2013 02:49 AM |
The selected ASIO audio device could not be initialized... | sneakyimp | Windows | 10 | 02-11-2012 11:10 AM |
"ASIO Audio Device Could Not Be Initialized" Error during MP 9 Start up. | Natronius | Windows | 6 | 01-25-2012 02:09 PM |
A Year of Headaches - "The Selected Asio Device..." | DoctorFills | Pro Tools 9 | 2 | 10-07-2011 07:56 PM |
Pro Tools 9.0.2 "the selectet ASIO audio device could not be initialized..." | Teltarma | Windows | 12 | 05-26-2011 06:32 AM |
