Old 11-10-2010, 10:21 AM
wasserwerk wasserwerk is offline
Default Re: DAE error -1115
Originally Posted by albee1952 View Post
The simple answer is because Avid says so. The next answer is because, what looks good on paper does not always perform good in reality(case in point; USB2 vs firewire 400). The last answer is because making a partition of the system drive actually stresses it MORE than simply recording to the system drive(C:). Either way, the head stack(the "pickup" that writes and retrieves data) now has to do twice the work(do all the mundane system stuff), AND do all the recording/playback audio stuff. That's a ()*&^load of work for any single hard drive.
Misunderstanding! I mean: "why not a 2.5" 5400 rpm as separate, external FW drive" in oposition to "it must be one external 7200 rpm drvie for autio recording".
regards
wasserwerk
Old 11-10-2010, 10:34 AM
spkguitar's Avatar
Because 5400rpm drives spin too slowly to stream audio properly.
Old 11-12-2010, 08:45 AM
When Avid sells a FW400 Interface like MBOX Por or Digi003 and says "you must use FW drive on Mac" then makes a fast 3.5" hard disk with 7200 on MacBook no sence at all because almost each modern 3.5"/7200 is faster even than FW800 - not to mention FW400, but you must use FW400 mode with your drive due to FW400 nature of audio interface. So I ask again - why 7200 HDD as external FW drive for tracking?
regards
wasserwerk
Old 11-12-2010, 08:52 AM
What means "not properly"? No properly for home projects on mbox with handfull tracks on MacBook? 10 tracks? 20 tracks? That is probably not serious. Hard disc recording is older than todays +100 MB/s 7200 drives. When this was possible 10 years ago, than this must be possible today with acurrent fast 2.5" 5400 drives.
regards
wasserwerk
Error 1115...HELP! jacobmoon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-24-2012 08:24 AM
DAE 1115 Error with PT 7.4 (win xp) Gwydion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-02-2011 11:25 AM
DAE Error 1115 Dtoxic911 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-11-2006 05:57 PM
error 1115 Fotrac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-11-2006 09:19 PM
DAE error -1115 saw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-18-2004 07:23 PM
