Old 05-26-2010, 04:34 AM
chilisexnbeer chilisexnbeer is offline
Default Mbox 1 And Snow Leopard
Hi All
I haven't seen any posts yet that say the following: (and forgive me if I've missed something...)
For all those people ready to scrap the original Mbox 1 - I have it working perfectly using Core Audio Drivers in Snow Leopard 6.3 and Logic 9.11.
Everywhere I look it says that this doesn't and can't work - but it does!!
So from what I can work out - Digidesign have taken this great tool and made it redundant for their own software but perfectly capable in their main rival's software...huh?
Test it out and tell me I'm wrong here...
big al
Macbook Pro 2.4Ghz | 4Gb RAM| SL 10.6.4 | ProTools 8.01 | Logic Pro 9.11 | MBox 1
Old 06-02-2010, 06:07 PM
devanbumstead devanbumstead is offline
Default Re: Mbox 1 And Snow Leopard
Yep, see this link, download this coreaudio driver and your MBox should work with whatever you want...at least it worked for me with Reason 4 and GarageBand so I assume it would work with Logic
http://www3.digidesign.com/index.cfm...4&itemid=40792
Old 06-02-2010, 06:13 PM
Craig F Craig F is offline
yes, it works now but you are locked into the version you are using (with any and all bugs and/or instabilities)
what will not work is 8.0.3 and all future releases
Thank you,
Craig
Old 06-02-2010, 08:07 PM
Skyflash Skyflash is offline
You'll also be stuck at a minimum 512 buffer and have crappy latency for using VI's
2006 'Blackbook' Core Duo 2.0 ghz.
2 gig OWC RAM
10.5.8
PT Mpowered 8.04, Logic 9.1.1
Waves SSL,Omnisphere,Korg Legacy Digital
Absynth 4, EZ Drummer
Project Mix I/O w/ Black Lion Mod
Axiom 61,25, Korg Nano Pad
Old 06-29-2010, 06:51 AM
As a useful update:
You can't use the Mbox to play system sounds/iTunes as it doesn't register in the sound preferences panel...
However, you can use the browser built into logic 9, then find the track(s) you want to play. If you play it a this point it still plays through the system card...however, if you turn on cycle mode, press the MAIN logic play button, and THEN play the track through the browser, it plays through the mBox...;-)
Well, I liked it anyway...just another way to beat the digi/avid mbox defunct system limitation
al
mbox 2 with mac snow leopard? floplight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-03-2011 07:24 AM
Mbox 1 and Snow Leopard ta56636 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-01-2010 09:53 AM
Original Mbox and Snow Leopard LoganGrime 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 04-07-2010 10:03 PM
MBOX 1 + snow leopard remon_ubasart 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-23-2009 07:20 AM
Snow Leopard and Mbox 2? merula 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-08-2009 10:00 PM
