  #51
Old 12-01-2013, 02:39 PM
Default Re: Trasher 10, a PT utility app for Windows users
Originally Posted by davgrn View Post
My anti virus software says this is dangerous as well
Most antivirus will ping small .exe files as a virus as it does not know what it is.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
  #52
Old 05-02-2014, 12:28 PM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
Win 8.1 Update 1
PT 11.1.3
I started getting "Could not initialize audio interface" messages when opening sessions that had been fine. Tried (nearly) everything. Was driving me NUTS.
I remembered seeing this utility mentioned in this forum. Downloaded, installed, trashed my prefs and *bingo* - sessions opened and played just fine.
THANK YOU!
I little bit of gratitude is coming your way via PayPal.
  #53
Old 05-03-2014, 06:46 PM
Originally Posted by BCnSTL View Post
Win 8.1 Update 1
PT 11.1.3
THANK YOU!
Thank you for the kind words and donation. Its all greatly appreciated!!
pro-tools-pc.com
Intel I7 9900k
Win 10
  #54
Old 11-11-2014, 06:27 PM
Trasher has been updated.
pro-tools-pc.com
Intel I7 9900k
Win 10
  #55
Old 02-15-2015, 05:08 PM
philip888's Avatar
philip888 philip888 is offline
Is the latest version of Trasher ok to work with PT 11.3.1?
Thanks
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7
  #56
Old 02-15-2015, 05:23 PM
Thanks
My latest release works fine in 11.3.1
pro-tools-pc.com
Intel I7 9900k
Win 10
  #57
Old 02-15-2015, 07:39 PM
philip888's Avatar
Great thank you.
  #58
Old 03-27-2015, 05:45 PM
Trasher updated for 12. The previous build 8 of Trasher 11 will work for Pro Tools 12.
Trasher 12 contains a bit of code updates and a new Plugins section containing tools for Fxpansion (BFD) and Softube (Console 1) and Waves.
Trasher 12
pro-tools-pc.com
Intel I7 9900k
Win 10
  #59
Old 04-13-2015, 06:36 PM
maunaloa maunaloa is offline
guitardom, the readme in Trasher 12 says (as I understand it), copy zipped file to desktop, extract to c:\
which should produce a file path c:\TRASHER 12\Data\TRASHER
only... it doesn't
The file path is c:\TRASHER 12\Data\TRASHER\App Files\...
The TRASHER 12 Installer file is in
c:\TRASHER 12\Data\
but regardless of where I extract, I get an error "can't find file".
Another readme says install in the Documents folder.
ASRock X99 OC Formula mobo, Win 8.1 x64, PT HD 12.1, i7-5960X CPU, 32GB G.Skill 2133 RAM, Intel 750 PCIe SSD boot drive, ASRock TB2 AIC, Sonnet Tech III-D with 2 HDX cards on TB2, Omni, HD I/O, S3, Artist Transport, SSDs and spinners, AMD HD 7990 GPUs, 2 HP ZR30w panels on DP.
  #60
Old 04-13-2015, 07:03 PM
only... it doesn't
c:\TRASHER 12\Data\
The file path is correct, that was just an abbreviated. Your file path is correct.
Are you running the installer from the folder it extracted to and not moving it??
You can just drag the Trasher folder OUT of the Data folder and drop it in your documents. Then in the App files folder is an Exe folder. I prefer to right click the Exe and "pin to task bar" or "pin to start menu" and leave the Exe in the folder.
pro-tools-pc.com
Intel I7 9900k
Win 10
Trasher 11, PT utility for Windows users guitardom Pro Tools 11 7 11-24-2013 09:12 AM
TRASHER for Windows 7 markus44uk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-23-2011 07:39 AM
Trasher support utility for PT9 and W7 guitardom Pro Tools 9 1 11-30-2010 10:17 PM
PT9 Trasher app windows 32 bit Raoul23 Pro Tools 9 3 11-24-2010 12:10 PM
Quicktime to Windows Media Conversion Utility hitp Post - Surround - Video 8 07-24-2004 01:27 PM
