iLok problem
Hi
I recently downloaded my free upgrade to pro tools 8, however my new iLock license for version 8 wasn't sent to my iLock account for some reason. So I am unable to authorize my new version of pro tools. Do you know how I could resolve this? Any help would be greatly welcomed. Thanks |
Re: iLock problem
Thanks for the help :)
However I am still having the same problem, when I go into my digi page it says I have used all my activation codes. I don't know if this will help but, when I go to click on the pro tools icon on my desktop it comes up with the message " This version of pro tools 8 requires authorization to run but the authorization cannot be found in the installed iLock". |
Re: iLock problem
IIRC I had to go revisit ilock.com and then do a synch. I think the best advice is to keep going back to your "My Digi" account and make sure you click the Downloads link. Stuff kept showing up there for me. The process works, it's just a little convoluted and non-intuitive.
PT 12.8.2 macOS Sierra 10.12.6 iMac (27-inch, Late 2012) 3.4 GHz Intel Core i7 16 GB 1600 MHz DDR3 Interface Focusrite Saffire PRO 24 |
Re: iLock problem
LE doesn't of course but m powered does.... |
Re: iLock problem
It sounds like you downloaded and installed the wrong version of Pro Tools (probably M-Powered or HD/TDM, which do require an iLok).
Verify the version of Pro Tools you have installed. If your signature is correct, you should only need your authorization code, which you can find on your MyDigi page. If, indeed, you are running M-Powered or HD/TDM, then log into your iLok account and look on the left for 'Download Licenses' - your iLok licenses will be there. |
iLOK log in problem | Maddern | Pro Tools 9 | 5 | 01-19-2012 05:17 AM |
iLok problem please help! | Scott Cairns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-30-2007 05:31 AM |
iLOK PROBLEM | PHANmale | Pro Tools M-Powered (Win) | 2 | 01-15-2007 11:38 AM |
iLok problem... | rc86mike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-03-2005 12:45 PM |
