Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
  #31
Old 08-31-2007, 12:57 AM
matchlessgift matchlessgift is offline
Default Re: Project mix problem
Ok problem fixed, so i took the whole setup down to my supplier and here is what they did, maybe useful for others to know:
Tried many things, uninstalling drivers / m powered, deleting preferences and maudio/digi related files from library folders, etc. Also tried upgrading from 10.4.8 to 10.4.9 and also 10.4.10, using the combo update not software update, nothing worked.
Solution:
1) a Mac OSX reload over the top, choosing 'Archive and Install' option, which retails all programs, settings, and user files. This resulted in a working 10.4.7 system.
2) Loaded the M-Audio 1.8.2 drivers, and noted that midi ports now did show up!
3) did an auto software update to bring it up to 10.4.10 ( i know this isn't recommended)
4) Ran that pre-binding fix, you fix the 10.4.10 issue with tools not working after auto update.
5) Reinstalled M-Powered 7.3 and 7.3.1 patch, as Pro Tools is the only software i've seen that doesn't survive an Archive and Install load of OSX.
Fired up tools, added the project mix as a HUI surface, loaded a recent project, worked 100%.
So basically something in file system was screwed, and neither the ProTools uninstaller nor the m-audio driver uninstaller correctly removed everything and put it back. But it works now, and all files/desktop background/passwords/settings and all other apps work fine.
Thanks go to Rowen at Derringers Music
IMAC Intel Core 2 duo 4G RAM
OS 10.4.11
Project Mix I/O
M-Powered PT 7.4
  #32
Old 08-31-2007, 06:56 AM
bradch00 bradch00 is offline
That's good news... it does sound like it had something to do with how AMS was originally installed. Now comes the fun part...
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
A problem with project from another comp. emersonrailroad Pro Tools M-Powered (Win) 1 04-06-2009 02:09 AM
Project mix install problem 40bends Pro Tools M-Powered (Win) 0 01-19-2008 10:17 PM
Monitering problem with project mix Chewits Pro Tools M-Powered (Mac) 1 07-18-2007 02:28 PM
Problem with HUI and my Project Mix I/O fooloof Pro Tools M-Powered (Mac) 2 02-10-2007 10:36 AM
Saving project to CDR problem. rdpete General Discussion 2 11-23-2000 01:06 PM
