Old 06-17-2003, 12:22 AM
Roy Howell Roy Howell is offline
Default XP Advice on separate profiles to improve PT performance...
I'de appreciate some advice on this... I know you can have separate Hardware profiles and turn off your NIC card in one of them.
But what I'de like to do, is to be able to sign on with one name with all normal processes running and all hardware loaded normally. But, with a second name, have most normal processes disabled at startup, so PT runs better. (With running processes OFF, I was just able to add 5 RenVerbs to a packed session that would barely play earlier today).
Is there a way?...thanks, Roy
rh music
Old 06-17-2003, 02:00 AM
Lalaman Lalaman is offline
Default Re: XP Advice on separate profiles to improve PT performance...
Hi my friend,
The current session on the PC here has grown to 2,08 GB size, being set to 128 samples buffer, contens 29 tracks audio, 48 midi, 9 aux, one master and 6 to 7 of the heaviest plugs ( reverbs, comps, amp modulator.)
Kontakt is also launched to deliver 13 instruments each containing samples of 3 to 6 mb. It records without probs I also can leave it open in the background when opening other apps or entering the internet.
This is probably outstandingly good performance with only an XP 1800 CPU even more as PT is set to S/PDIF.
As there is only done minor tweaking ( like disabled system sounds etc.) it could be that one doesn´t really need to disable any cards.
I have the impression that the way the OS disk is defragged could be an efficient question instead. Since I tried out defragging by a thorough method where files are gathered by their names I have the impression like that would do very good to the system.
The program I used for it is named "O&O Defrag Professional Edition", maybe you would like to try that one out.
After having defragged with it first time ( takes longer than with WinXP defrag, cause more detailed ) PT first runs just normal or maybe even a bit worse for the first hours ( I assumed maybe because certain files need to get placed on another spot first while system conducts ), but afterwards it seems all to get stable like hell.
Greets,
Lalaman
Old 06-17-2003, 11:02 AM
Thanks Joe...I think that may help, and I've emailed you about it.
But I also want to know if it's true that separate 'User Profiles' can be set up, each with it's own 'running processes' setup.
All I see is 'Hardware Profiles', which pertains to hardware only, and 'User Accounts', which only allows irrelevant changes to be made.
thanks, Roy
rh music
Old 06-17-2003, 11:32 AM
silence_of_stone silence_of_stone is offline
I am interested too Roy. I will be following this post pretty closely. I havent had much trouble with my xp2600 yet, but as with everything, I will eventually find the limit.
Ad astra per aspera...
Old 06-17-2003, 11:48 AM
Well in the skyking thread about using XP with other programs, Allen says:
"Originally posted by Allen Hallada:
With XP it is easy to setup different user profiles so I'd recommend setting up a profile just for PTLE that limits the programs running in the background.
Allen "
Allen...how can this be done?
thanks, Roy
rh music
Old 06-17-2003, 11:50 AM
thanks, Roy
<font size="2" face="Verdana, Arial">That´s exactly what I remember from my trials. Different user profiles didn´t mean different hardware configurations. When I disabled devices in hardware manager they would show up disabled also in other profiles. So I skipped on that idea, but maybe there is a way somehow and someone of the DUCs wisdom will certainly know of it then. [img]images/icons/smile.gif[/img]
Old 06-17-2003, 03:33 PM
bump..................
rh music
Old 06-17-2003, 04:59 PM
it floats...
rh music
Old 06-17-2003, 05:00 PM
Scoobster Scoobster is offline
Roy rather than try to explain it here, have a look at this site hardware profiles I know it's a gaming site but I've found that gamers are often the most informed and have a vast knowledge of tweaks and downfalls of operating systems.
Cheers
Scoobster
Old 06-17-2003, 09:17 PM
Thanks Scoob... I guess nobody else with the answer saw this thread...(yeah right [img]images/icons/wink.gif[/img] )
I had disabled services on my main profile recently, but had to cut them back on. If they can indeed be disabled in a separate profile, it'll do wonders for PT performance, as I just witnessed yesterday. I'll look into this now.
I appreciate it, Scoobster... [img]images/icons/cool.gif[/img]
rh music
How to improve performance of VI's in Pro Tools. DigiTechSupt Virtual Instruments 43 04-25-2017 04:36 AM
Would putting plugs on a separate drive improve anything evilstudios macOS 18 01-20-2014 09:12 AM
Improve Performance matts9383 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-23-2004 08:03 PM
Will tons of ram improve performance? Dopamine Pro Tools TDM Systems (Mac) 1 11-01-2002 06:55 PM
IRQ Buffering to improve performance bstaley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-22-2000 10:39 AM
