Old 12-04-2019, 05:40 PM
tlharder tlharder is offline
Default PT 7.3 on Windows XP
After several years of inactivity, I am trying to get my Pro Tools set up running again. I have (and have very successfully) run PT 7.3 using an MBox2 Pro interface, on a laptop running Windows XP. But now when I went to start up Pro Tools it kept stalling on the stage "building DAE objects" (or something like that). On the internet I was advised to uninstall and reinstall PT. I tried doing so (via a download as my DVD drive doesn't work), but the reinstall keeps stalling out at the stage "Installing digidesign hardware drivers." It never goes beyond that stage. I often (but not always) have to do a hard re-set.
An undoubtedly related problem, but not sure if it's the chicken or the egg, is that my MBox2 Pro doesn't initialize. The power light just keeps blinking instead of staying on, the way it used to. (And it came on as little as a week ago, but that was before I uninstalled and tried reinstalling.) Does the reinstall have to finish completely before the MBox2 Pro will initialize? Or does the MBox 2 Pro have to initialize before I can complete the reinstall? (Either way I'm stuck.)
I was just getting to know my system (and had produced five CD projects with it). I am hoping I can keep using it, as it was a significant investment. Help would be much appreciated.
Tom Harder
Old 12-05-2019, 06:01 PM
Default Re: PT 7.3 on Windows XP
Not sure if I can help, but....are you doing the install by following the original instructions, or just clicking and hoping? From a "clean" starting point(no left-over traces of failed PT installs), you would run the installer with the Mbox NOT connected. When the installer tells you to connect the interface, connect the Mbox>wait maybe 8 seconds and then continue. The next most important detail was/is to ignore any popups reporting "New Hardware Found". Don't click on those at all and they will(should) go away on their own Hopefully you have the authorization code(the code that starts with "DIGI0......"). Without that, you'll be stuck even after a successful install
Pro Tools tabbed windows in MacOs - Windows configuration not working hugocentrique macOS 2 05-07-2018 12:57 PM
Audio glitches with Fast Track Ultra on Windows 10 after updating Windows 10 GregS FireWire and USB Audio Interfaces (Win) 6 12-25-2015 04:40 PM
Windows Guide - Windows 7 Optimizations and Troubleshooting.[349411] cwsand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-12-2010 02:46 PM
Is standalone Windows Audio Drivers v8.0.3 compatible with WINDOWS XP 64 ? VonHelvete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2010 11:01 AM
Windows server 2003+windows resource manager. odysseys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-20-2003 11:02 AM
