Old 09-09-2019, 04:26 PM
ZdonTheRapper ZdonTheRapper is offline
Default When ProTools is open there is no sound coming from YouTube
When ProTools is open there is no sound coming from YouTube. I used to use a mac and I could do it back then. I switched to Windows and I suspect this has something to do with it. My playback engine used to be an Aggregate Device that I made in Audio Midi Setup on the Mac, but now it is ASIO4ALL-V2 and for some reason when I try to select the playback engine to change it it won't allow me to. Like it's greyed out and disallowing me from changing it. Idk if this problem is fixable but I would love to be able to watch YouTube tutorials while using ProTools. (btw, I'm using ASIO4ALL-V2 because I don't have an M-Box or other Hardware Interface) Any insight is appreciated. Thanks Again.
Computer: Dell Latitude E6410
Processor: Intel Core i5 M520
Speed: 2.40Ghz
RAM: 4GB
Hard Drive: 320 GB
OS: Windows 10 Pro 64-bit
Pro Tools Version: 10.3.10 using ASIO4ALL-V2
ILok: ILok 3
Old 09-09-2019, 05:13 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: When ProTools is open there is no sound coming from YouTube
Please get an interface. Unless your interface's drivers allow it to be used for both PT and Windows sounds/audio use the interface only for Pro Tools and set your onboard sound card as the default for Windows sounds/audio. No aggregate on PT on Windows.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 09-10-2019, 09:43 AM
Thanks, it's good to know that it's possible at least. Aprreciate it.
Speed: 2.40Ghz
RAM: 4GB
Hard Drive: 320 GB
ILok: ILok 3
Songs sound distorted on Youtube TV thinvaluecheck Pro Tools 11 8 12-24-2016 08:48 PM
Youtube wont run when pro tools is open (Win 10) scottsl Pro Tools 12 5 12-06-2016 02:47 PM
No sound coming out Protools 8 Mac Laptop julianlede 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-19-2011 01:35 AM
Help. No sound coming out protools LE 8.0 and mbox 2 llubell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-19-2010 11:24 PM
No sound coming from protools TDKshorty 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-01-2010 07:51 PM
