Go Back   Avid Pro Audio Community > Pro Mixing > Avid S1, S3, Dock and Control
Old 11-21-2017, 04:40 PM
Kevin Sound Snipers Kevin Sound Snipers is offline
Default Calling up AudioSuite plugins in PT Control
Hey All
I've been trying to figure out how to assign AudioSuite plugins to Soft Keys in PT Control. It seems to be the only drop down menu not included ! i'm sure theres an easy explanation though ... anyone ?
Cheers
Kevin
Old 11-21-2017, 10:00 PM
Anthony_Anz Anthony_Anz is offline
Default Re: Calling up AudioSuite plugins in PT Control
Originally Posted by Kevin Sound Snipers View Post
Hey All
Cheers
Kevin
Are you on Windows or MAC?
Under windows pressing the ALT key (on the keyboard) activates the menus at the top (denoted with underlines), then pressing the "a" key shows the AudioSuite dropdown menu. There used to be a way to get this to work with a Softkey with some keyboard shortcuts but I just tried this here again but it did not work... bummer.. if we could get access to the menus at the top via a keyboard shortcut, then a Softkey with some keyboard shortcuts would do exactly what you need.
Old 11-22-2017, 01:44 AM
crustn crustn is offline
You can use window configs for this. They can be recalled with soft keys and if you are using the same audio suite PI in different sessions you can save them in a template session and then import in other sessions with import session data.
Old 11-22-2017, 11:04 AM
Thanks for the suggestions guys. I also came across this in case its useful to anyone else.
Cheers
http://www.pro-tools-expert.com/home...-plug-ins.html
Old 11-22-2017, 12:11 PM
Unfortunately the above works great but not as a softkey . When trying to use the Eucon Command Keypad number - it seems to keep resetting to using the regular number keys instead.
Audiosuite Plugins odeu87 Pro Tools TDM Systems (Win) 2 07-21-2010 10:35 PM
Plugins Vs Audiosuite gz131 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-20-2004 10:24 AM
audiosuite plugins prs24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-30-2003 03:11 AM
Audiosuite plugins in HD waves3 Pro Tools TDM Systems (Mac) 5 03-29-2002 01:27 AM
