Old 11-29-2015, 12:34 PM
andy.T andy.T is offline
Default Pro Tools 11/ElevenRack setup for recording?
Hello,
I have problems to setup PT11 and ER to make guitar recordings.
In WIN 8.1/64 drivers for ElevenRack are installed and work with standalone editor. I use Roland Quad Capture USB interface and Allan&Heath ZED10FX as analog mixer. Quad Capture, ER and the A&H working standalone in WIN. When I open PT11 I can set QC to playback engine and I can play an imported audio backintrack but I have no ElevenRack in I/O settings.
Signal flow:
Guitar->ElevenRack->Allen&Heath->QuadCapture->Poweramp->passive studio monitors
What is wrong?
THX
Old 11-29-2015, 02:19 PM
sw rec sw rec is offline
Default Re: Pro Tools 11/ElevenRack setup for recording?
Go into Control Panel and make sure Windows is NOT designating your rack as the default sound device.
Old 11-29-2015, 02:31 PM
Benoni's Avatar
Benoni Benoni is offline
If you are using the Quad Capture as your interface then you won't have the Eleven Rack inputs because it is not your interface for Pro Tools.
You can run analog into the Quad, or SPDIF if that is an option. Or switch the playback engine to Eleven Rack (and default the IO) to have the Eleven Rack inputs in Pro Tools.
Old 11-29-2015, 03:12 PM
The Quad Capture is the problem? I must use an other interface to have ElevenRack as input?
What is the best alternative?
Old 11-29-2015, 03:42 PM
Benoni's Avatar
No, not use another interface, you must use the Eleven Rack as the interface. The Eleven Rack IS an interface as well as a guitar effects unit.
Unplug the Quad. Plug the USB from the Eleven Rack to the PC and you will have the Eleven Rack inputs.
If that is not your question, please rephrase it and tell us exactly what you are trying to do.
003 and Elevenrack in Pro tools 11 andymonize Pro Tools 11 3 08-16-2014 12:08 PM
Apogee ONE I/O setup- not monitoring or recording in Pro Tools 10 asmusic Getting Started 2 07-29-2013 02:01 PM
Pro Tools session mixed in the box. Recorded with Elevenrack protoolsitb Eleven Rack 0 09-19-2012 01:54 PM
Help with ElevenRack in Pro tools JonWillford Windows 0 05-13-2012 08:16 AM
Live multitrack recording with ElevenRack adamqlw Eleven Rack 2 04-02-2012 05:58 PM
