Old 03-14-2014, 04:33 AM
Aster Aster is offline
Default Imported WAV tracks out of sync
Hi , I have sampled a song track by track (From Fantom G) and then imported the resulting wav files into protools and have noticed all the tracks are slightly out of sync timewise...any ideas / suggestions ?
Thanks
Old 03-14-2014, 08:54 AM
sw rec sw rec is offline
Default Re: Imported WAV tracks out of sync
Using 10? 11? What interface?
Old 03-14-2014, 10:51 AM
Hi using 11 and mbox 3 pro...
Old 03-14-2014, 11:31 AM
Importing as dual mono, multi mono, interleaved....
PT 11-xx.xx???
Old 03-14-2014, 01:14 PM
Craig F Craig F is offline
Please define "out of sync" better:
are they out of sync with them selves from Fantom G
do they get progressively worse from start to end
trying to define if it's an offset or a run time problem
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 03-15-2014, 05:25 AM
So i have lined up the tracks properly, but there seems to be a timing issue between the tracks...i recorded/sampled the tracks at 120 bpm....should i try quantize in protools, time stretch...not sure..sorry this is the first time i have tried this..
Old 03-15-2014, 03:12 PM
You did not address one of the questions I asked so I can not help you
Thank you,
Craig
I Imported stereo tracks , but PT reads as 2 L&R Mono tracks ? Seafoam_Green Getting Started 9 02-01-2014 10:29 PM
How to sync tracks imported from one session into another JoeChristopher Pro Tools 9 5 12-10-2012 09:38 AM
7.3.1 CS3. Imported video trk is 2:30 out of sync tsr2 Pro Tools TDM Systems (Mac) 0 07-05-2007 05:28 AM
How sync up imported drum tracks barketta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-21-2005 09:25 AM
How to Sync imported drum tracks barketta Tips & Tricks 0 02-19-2005 12:05 PM
