Old 04-28-2011, 04:00 AM
midnightrambler midnightrambler is offline
Default Re: 9129, 9092, 9093 errors
I've had my HD Native system a few weeks now and I've not encountered any of these errors yet. I wish I could tell you what I was doing "right", as far as I know spotlight etc are all on their default settings.
Old 04-28-2011, 07:31 AM
paranerd paranerd is offline
I get these once in a while too, but, like everyone seems to be saying, there doesn't seem to be any logical reason for it.
I have my HW buffer at 1024 with long ADC. I've been mixing 30 minute shows with a conservative number of EQs/Comps/Limiters/Meters for the past 2 months without any problems other than the -9129 popping up occasionally (maybe 4 times?). Yesterday, I was simply listening to an edited session with no bussing or plug-ins and it came up with the -9129. Just clicked OK and kept on working.
All my sessions and its materials, video and audio, are on an external drive connected via USB2, but I'd be expecting a "can't get to disk fast enough" error instead and I haven't had any of those.
Specs:
PT HD 9.0.2
HD Native with 96 I/O
MacOSX 10.6.6
2 x 2.26 GHz QuadCore
6GB DDR3 1066Mhz
The Postman Post-Production Studio
Moncton, New Brunswick, Canada
IMDb (very partial)
Old 04-28-2011, 04:50 PM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Originally Posted by JR Fountain View Post
I seem to get 9092 errors whenever I'm looping over a region and tweaking a plugin.
I get similar issues when plugin tweaking. The amount of CPU load seems to make no difference at all.
Old 04-29-2011, 07:47 AM
jem777 jem777 is offline
I am fighting with this errors for some time now and opened a case with Avid. We have tried several things but no solution yet. Just thought might share some informations with you.
MacPro 8 core, 10GB Ram, HD Native w. Omni IO, 10.6.6, PT 9.0.2
Based on the chosen buffer size, the errors are differing. At 256/512 i get mostly 9092 and 9094 popping up, at 1024 mostly 9094 and at 2048 error 9129 shows up.
I'm having/had the impression that i can force the error by scrolling either with the scroll-wheel or with the page up/down keys on the keyboard. First i thought that my graphic-card (ATI 2600 XT) had something to do with it (maybe not enough Video-RAM), so i exchanged it with a new ATI 5770, but no success.
After going thru every possible setting in Playback engine with AVID support nothing really helped, the error even appears in a session with 2 Audio and 1 Master track, no plugins. The lower the buffer setting, the more often the error appears.
I then followed a recommendation in this post and switched from my HD Native/Omni playback engine to the built-in audio device and you won't believe it, the error was gone ! In a not so small session (but not really that big and not so many plugins) i could not work at 2048 buffer size without getting the 9129 error frequently, maybe 10-15 times or so in half an hour, sometimes more than once in a minute. I changed to built-in audio then and could work for 5 straight hours, and that on 512 buffer size ! I worked now for two more days with this setting and did not get the errors again.
In my opinion there is something wrong with the combination of my HD Native/MacPro setup, maybe some interrupt-thing (or driver issues) with the graphics PCI card or whatever, just guessing.
So next week AVID support is continuing looking into it, i have send them the session for further investigation. I will let you know about new findings or a solution to this, I really hope i can get rid of it because right now working has become almost impossible with these errors popping up so frequently. I had a vocal recording session a week ago and it was very disappointing for the singer when the recording stopped for no reason in the middle of takes, it's not just playback-related. I am not a commercial studio, otherwise this would be a disaster. Having done this kind of investment i would expect a more stable experience, but there is still hope ;-)
Regards
Bertrand
Old 05-03-2011, 12:18 PM
JR Fountain JR Fountain is offline
This error is killing me now. I'd up'd my buffer to 512 and had been working happily on a project for the last 3 days no problems. Today open up to work on another show and things were going fine til about 10 minutes ago, now I can barely play a few seconds without the 9092 or 9093 error coming up. When I look at my CPU meter the RTAS meter is jumping all over the place and I don't have much going on plugin wise. Even after a restart things still are not working properly.
JR
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12
  #16
Old 05-03-2011, 01:05 PM
Jack Ruston Jack Ruston is offline
I have been running with both ethernet ports disabled at tech support's suggestion. I have had no errors at all. But I hardly ever getting them so I'm waiting before concluding that this has cured it. Might want to try that and see what happens.
J
www.jackruston.com
  #17
Old 05-03-2011, 06:39 PM
Ya unfortunately I've got my artist series controllers plugged in there. Kinda need them right now for the project I'm working on. I'll give that a try once I've got some down time but even then that's not exactly a solution.
It'd be nice if DTS would chime in here, certainly seems enough people are experiencing this to warrant a response.
Thanks,
JR
J.R. Fountain
  #18
Old 05-03-2011, 11:13 PM
Jon_Atkinson Jon_Atkinson is offline
Default
Hi JR,
You'll have to forgive me if you've tried this already, and also allow for the fact that I'm not an HD Native user, so I may be completely incorrect....
Are you absolutely 100% sure that these errors are not plugin related...?
It's just that these type of errors in any other PT rig sound exactly like the sort of thing you'd get with an incompatible plugin.
Mac Pro 2019 3.5GHz 8 Core 48GB RAM
OS 13.6.3
Protools Studio 2023.12
Antelope Orion 32, Vienna Ensemble Pro 5,
UAD Quad PCIe
  #19
Old 05-04-2011, 01:33 AM
Jack Ruston UK Jack Ruston UK is offline
Thanks,
JR
It'd be good if you could try it while you're getting all these problems. At least we'd know for sure. There are cases open on this and if we have a solid cause they can look at a fix. It seems somewhat more likely now hearing that you're using controllers. Perhaps that explains why you get it all the time and I hardly ever do.
  #20
Old 05-04-2011, 06:04 AM
DigiTechSupt's Avatar
This issue has been brought to my attention by other techs (and the DUC posts) and we're continuing to investigate. As Jack says, it would be good to know if disabling ethernet 'fixes' it.
Either that or, if you can repro the error easily, do so then immediately quit Pro Tools and email me your log files folder (MacHD>Users>your account>Library>Logs>AvidLogFiles). Zip it up and send it to me at: vi (at) digidesign (dot) com. It may tell us something about what's going wrong. Please include either the thread title or number in the subject of your email as well as your DUC username.
Avid Audio Tech Support
Support FAQ
9092, 9093 and 9129 error update? Mascola24 Pro Tools HDX & HD Native Systems (Win) 4 09-28-2011 06:10 PM
Help! Errors 9092, 9093, 9094, 9129 persisting! doobaGeoff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 05-27-2007 06:32 PM
9092, 9093 errors when minimizing WilliamDC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-10-2006 03:31 PM
Interrupt errors -9092/ -9093/ -9094/ -9129 saxbill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-18-2002 11:41 AM
Studied all posts on 9092 9093 9129 however, these errors are still driving me NuTs! Wildberrie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 12-06-2001 05:10 AM
