Old 01-01-2018, 10:52 AM
Mark Kieviet Mark Kieviet is offline
Default Pro Tools 11 with unsupported buffer size REAC Driver
Hello,
I'm an owner of pro tools 11 and a Roland m400 with 2 1608 stageboxes.
I want to use this to multi track, with the REAC driver this should be possible on Windows. After installing my Bootcamped Windows i tried to launch Pro Tools with the REAC driver as playback engine. But the REAC driver uses 2304 samples as lowest buffer size. So this is NOT supported by Pro Tools. Is there any way around this error, so I would be able to use Pro Tools with my live setup?
Thanks in advance,
Mark
Macbook pro medio 2012, 2,9 ghz i7 (2core), 16gb ram, OSX 10.8.5
iMac 2013, 2,7 ghz i5 (4core) 8 gig ram, OSX 10.9
Alesis io26
Presonus FP10
Pro tools 11
Old 01-01-2018, 11:36 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Pro Tools 11 with unsupported buffer size REAC Driver
Isn't the REAC driver only useable with SONAR?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-01-2018, 11:48 AM
The REAC driver is supposed to be an ASIO driver and should just work... but Roland just does not enthuse me with confidence with any of their audio interface stuff, especially drivers.
It is hard to believe you cannot set the buffer size to smaller than this.... from their software, and with nothing else using the interface. If you cannot do that I would take this question up with Roland support.
Unsupported Audio Buffer Size Error ProTools 11 Win10 thegrinch Pro Tools 11 2 09-17-2017 09:26 AM
Device is configured with an unsupported buffer size sp_key Pro Tools | Intro Discussion 1 08-18-2015 12:04 PM
Pro Tools 10.3.6 won't launch, unsupported buffer size error with ProFire2626 LarrySmileyEL Pro Tools 10 7 01-10-2015 12:55 AM
FYI: PT 10.3.3 complains about unsupported buffer size 2048 Niilo Nuori Windows 0 02-22-2013 03:43 PM
ProTools won't launch; unsupported buffer size DarylG Windows 3 02-23-2011 08:07 AM
