Re: Need your opinions on first mix/master
Thank Manny! I panned the snare a bit left and added a little more low end to the master.
I have not messed with room mic placement in Superior Drummer yet. I am sure there is a way, but I haven't gotten that deep. https://soundcloud.com/davebmetal/im...ory-of-failure Last edited by davebmetal; 06-01-2013 at 04:08 PM. |
Daveb,
That mix is coming along with much more prescence than the first mix in the drums. I still feel like the balls are missing. You definitely have some frequencies battling each other and I still feel like there's a little compression on the output buss. I think the struggle with the drums may be using Superior drummer, I've used samples in the past with heavy music, but always found the heaviest sounds came from a real live kit. This track should rip peoples faces off. The same can be said about the guitars, the riffs are there, but into the first chorus the rythm guitar gets masked; a real amp with a mic could go a long way. How many guitar tracks do you have going? Are they using different patches? Did you double them or just copy/paste? Personally, for guitar sounds(if you haven't done this already) record two of the exact same takes, pan one to the Left a bit and equally pan the other to the Right. You'll get a bigger, heavier sound. What was the Bass recorded with? just DI? Either way, if this is just a demo, it's good! Get it professionally mastered and move onto the next track...don't get too caught up, the more recordings and mixes you do, the better they'll get. Makes me miss working on heavy music, for now, back to brushes and accoustic guitars :P
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
Hi Manny,
You are right, I don't have raised monitors. I'm just mixing in my bedroom. I will get those monitor lifts soon enough. I also want to try getting a good pair of headphones. Hi Dr. DAW, I recorded all guitars and bass through the Line6 UX2. I did two takes of rhythm guitars - one 95 right, one 95 left. I used different patches for each. The guitars you hear down the middle are the other guitarists lead type tracks. During the chorus, he is using a heavy chorus effect. I may use automation to make it more even because I agree that the tones are battling each other. The Line6 patches had the compressor effect within that program on the patch. Next time I will use no compressor. I did master this thing with Ozone5. So that is likely the compression you are hearing. I do hear some mid to high mid frequencies causing some clashes. I will keep at it. And I know Superior is not a real kit, but the reason I use it is because this recording project was started because we couldn't get a real technical drummer in our area. And I do have a Marshall 4x12 and a Line6 HD147 head so I will start experimenting with using a mic set up too. Thank you guys for all your feedback and help. It has been invaluable. |
You shouls also consider investing in absorbers, diffusers and bass traps to help level the room a bit. It will not be perfect, but it will certainly help.
#16
Well, I think I got rid of those conflicting frequencies. But you all are correct, I will need to do some adjusting on the guitar tones in Line6 for the next song we do. I thought we got rid of most of the high end but one of the amp models I used was pretty high gain. Probably too much.
Better version: https://soundcloud.com/davebmetal/im...ory-of-failure Last edited by davebmetal; 06-04-2013 at 02:53 PM. |
Production Master Or Original Master | Zelos | General Discussion | 3 | 02-14-2011 07:52 PM |
Fixing Clipping in Master in Master Fader | pakobo7 | Pro Tools M-Powered (Win) | 10 | 09-16-2006 10:53 AM |
Master inserts are post-fader? Was: L1+ on Master = clipping | s2n | Pro Tools TDM Systems (Mac) | 10 | 11-20-2001 07:41 AM |
Master Fade & Master Plug Ins | Kenny Gioia | Tips & Tricks | 10 | 04-17-2001 02:39 PM |
MASTER TOOLS OPINIONS | L.R. | Tips & Tricks | 3 | 10-12-1999 09:41 AM |
