DAE Running out of memory...
Bounced a session down to wave file, and imported it into new session for mastering.... when I went to add the L2 plugin to my masterfader - the first, and only plugin on there, I received the message - "DAE running out of memory." It then made the plugin inactive. I've never had this issue before... I tried allocating more resources on my mac - in the setup window, buffer sizes, etc. not working.
I've used this methodology before in mastering projects - this is the first time this has happened. Please help! thanks. |
Re: DAE Running out of memory...
If rebooting doesn't help, you should delete this thread and post one in the appropriate forum - Mac or Windows LE, as the case might be - along with full system details as outlined in the Help Us Help You sticky at the top of that forum.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
PT9, Mac Pro, 10% CPU, 2GB mem used, still says Running Out of CPU and/or Memory | LewKellogg | macOS | 3 | 08-27-2011 04:34 PM |
PT running out of memory | Blackers | Pro Tools M-Powered (Win) | 10 | 06-30-2011 12:59 PM |
PT HD9 (running native with motu) running out of memory | syMPh | Pro Tools TDM Systems (Mac) | 1 | 11-21-2010 07:34 PM |
PT Running out of memory | JohnR424 | Pro Tools TDM Systems (Win) | 20 | 06-11-2009 10:15 PM |
Running out of memory? | Scott Cairns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-31-2007 08:20 AM |
