Old 04-09-2011, 09:40 AM
youbringmesuffering youbringmesuffering is offline
Default Control 24 - alternate to monitoring section
so i recently discovered how poor the monitor section is on this. AFter about 30 minutes, i lose tone out of my left monitor, sounding like it's phasing. turning it on and off fixes it but it's become a real nuisance.
So i'm looking for options. I interfacing PT9 through an Aurora going into the board. I'm eyeballing a D-box but i'm more of a composer/producer than an engineer, though i do have to do rough mixes from time to time so i'm trying to avoid super high end expensive stuff, tempting as it is. i'm looking for other means.
I've already looked into a central station and a mackie but i'm not liking the reviews. Any other ideas out there?
Jose
Old 04-09-2011, 12:16 PM
Default Re: Control 24 - alternate to monitoring section
Who gave a poor review to the Central Station? The beauty of it is that the signal path is all passive with zero coloration. I've been happy with mine for several years now. The only caveat is the headphone outputs seem to be polarity reversed from the mains. That came into play when combining the headphone feed to my headphone amp, with direct feeds from my interface. If I turned up, say the lead vocal while the vocalist had the main mix going(and wanted "more me", the vocal would phase cancel. Special cables solved it. As much as I like the Dangerous stuff, the CS works just fine IMHO(and is much more cost effective). I feed mine with both analog and digital from my interface, the optical output from my computer(for all non-PT sound) and I even have a feed from the headphone out of my Motif es8 so I can listen to the keyboard without PT(or even the computer). I even had a CD player available(ran out of rack space and removed it).
Old 11-04-2011, 05:45 AM
I figured it out. It was my patch panel.
Jose
Monitoring section of ProControls shuts off intermittently dongbin ProControl, Control|24, Command|8 2 08-30-2010 11:15 PM
help with 002 monitoring section; urgent biggun1234 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-21-2009 06:45 AM
Alternate monitoring on a 002? The Gaz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 12-05-2008 01:23 PM
D Control Monitoring Section tandem ICON & C|24 3 09-21-2006 10:12 PM
Pro Control Monitor Section-Please Read Techsupt2 General 0 11-03-1999 03:38 PM
