Old 01-11-2020, 03:47 AM
FunkzzaJ FunkzzaJ is offline
Default OneDrive/Document install path
Hi all !
Q: Uninstall and remove OneDrive completely?
The Documents folder, holds below folders as they all were installed by corresponding installers beginning year ago whith purchase of new computer.
Pro Tools
AIR Instrument Bundle
Air Music Technology
IK Multimedia
Toontrack
UVI
iZotope
...etc
However, the full path for e.g. the Pro Tools folder is:
C:/Users/MyUserName/OneDrive/Documents/Pro Tools
i.e. OneDrive is in the install path. I have un-linked OneDrive so it doesn't sync, but I'm not sure if this is how it should be. Does your installation path include OneDrive for the documents folder?
I feel it should just be cleaner and more 'orderly' to have the path like this:
C:/Users/MyUserName/Documents/Pro Tools
As I'm now about to upgrade PT (on 2019.6), and some plugs, I wonder if I should
1. uninstall - remove OneDrive - clean install
2. Remain with OneDrive but having it un-linked
Any thoughts ?
/FZZ
Old 01-11-2020, 04:45 AM
Default Re: OneDrive/Document install path
Unless you need cloud storage completely uninstall OneDrive. Reboot and update PT and plugins.
Jack
QAPLA!
Old 01-20-2020, 02:28 AM
Ok. Done. OneDrive gone. Happy.
Skickat från min Moto G (5) via Tapatalk
Free beer tomorrow !!
- but until then -
we're stuck in the present moment
Old 08-21-2022, 02:31 PM
Befuddled Befuddled is offline
I had the same problem on a new computer build/install. I solved the problem by going to Setup>Preferences I opened the Operation tab. There at the bottom left you can set where Pro Tools retrieves and stores the media and setting locations. I copied my files to the the documents folder under my user id and then changed the locaton to those directories. This could be cumbersome if you have a lot of data so I ended just creating a new Project file and let the system create new cache files. This not only made opening Pro Tools faster but also closing Pro Tools because it was writing data to the local drive.
2018 | install plugin path? chip_nelson Getting Started 8 03-31-2018 04:37 AM
Onedrive rant JuanPC General Discussion 18 07-13-2016 06:53 PM
can't create a new document quickgerund macOS 3 05-30-2014 02:38 AM
Document to new darkman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-13-2009 06:26 PM
Install Path for Vista Home Premium System akakpaws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-26-2008 12:05 AM
