Old 12-04-2013, 11:37 AM
chann48211 chann48211 is offline
Default Thunderbolt Interface
Newbie Question,
I am looking at purchasing the Pro Tools HD Thunderbolt interface and I noticed a few stores are just sealing the Thunderbolt interface bundled with Pro tools 11 HD software with no interface, Would not having an I/O interface cause the software not to work as indented to or would some features not be available until an interface is attached? Any help would be grateful!!
Old 12-04-2013, 11:44 AM
Craig F Craig F is offline
Default Re: Thunderbolt Interface
You would need an Avid interface (HD, Omni, or MADI) for the HD Thunderbolt to work
The software would run but you would be limited to Core Audio/ASIO options
An older Blue interface should work but no promises that it will or for how long
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 12-04-2013, 11:49 AM
Well, without an interface, you have no inputs or outputs Kinda defeats buying it in the first place, doesn't it? Now, on the other side of that, you COULD choose to save money buy buying a used 96IO or 192IO to get up and running. The software will run without the card as it CAN use the onboard audio ports of most computers(assuming you have a MBP with Thunderbolt or you wouldn't be asking), so yes, the software will run without IO, or the card for that matter. But, what is your work going to require? If all you need is to be able to connect headphones to edit/mix, then the onboard audio can work. If you want to actually record, then you need a way to get mic preamps connected to the system. For that, I WOULD get something for IO and the OMNI might be just what you need as it covers mic preamps AND monitor control. Describing your real needs will net better advice
Old 12-04-2013, 01:09 PM
Thanks for the info, I do want to add the HD Omni interface but can't swing both items at the same time. As the software will work with out an I/O but with limited option, it safe to say that I can but the Thunderbolt interface now and Omni three months down the line?
Old 12-04-2013, 01:27 PM
JFreak's Avatar
JFreak JFreak is offline
Yes you can buy the software now and interface later but until you have that interface you will not benefit anything from the thunderbolt box.
Janne
Old 12-04-2013, 01:29 PM
The Thunderbolt Interface is little more than the HDN card in a Thunderbolt box
I know it has the headphone jack on it but from what I can tell it doesn't work w/o an interface attached (less than ideal in my book)
Thank you,
Craig
Old 12-04-2013, 01:48 PM
JFreak's Avatar
I too would love it if the TB box could have such a firmware update that would enable using its headphone output without interface connected. It is after all miles better (and louder) than the one in the rMBP :)
Janne
Old 12-04-2013, 06:05 PM
Actually you don't need an Avid interface as such but one with the Digilink connector like an Apogee Symphony or Lynx Aurora.
Jack
QAPLA!
Old 12-04-2013, 06:24 PM
OK, but you still need something on the Digilink port
Thank you,
Craig
Old 05-27-2014, 05:22 AM
beefpitas beefpitas is offline
You might get some use out of the Avid thunderbolt interface if you have a Profile. I have seen a lot of guys tracking to their MBP with just the TB i/o and its a pretty slick system for live capture. No other hardware required. Only 64 channels though.
I also saw a guy do the same with an HD Native card and a Sonnet PCIe to thunderbolt chassis, which is probably cheaper, but doesn't have the HP jack.
Motu thunderbolt interface (828x) Marcel Risberg General Discussion 1 03-17-2015 09:27 AM
New thunderbolt interface John_Toolbox Third Party Interfaces 10 02-15-2014 12:34 PM
So what about new ThunderBolt interface and VENUE? digidesigner VENUE Live Sound Systems 6 02-18-2013 10:46 AM
HD native thunderbolt - without Interface ilulilu888 Pro Tools HDX & HD Native Systems (Mac) 1 09-26-2012 11:31 AM
HD Native Thunderbolt Interface M-ManLA General Discussion 16 09-10-2012 09:11 PM
