Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 06-21-2018, 03:16 PM
PaulTMA PaulTMA is offline
Default How to set nudge settings to milliseconds in Pro Tools first?
I have just started with Pro Tools First, after being familiar with Logic Pro X. The reason for this is so I can use elastic audio, which I've been recommended strongly over flex time in Logic, which I could never get to grips with.
The person who I have previously paid to do my edits for me, said that the setting he uses for manually moving notes around are setting the grid to 1/8 and nudge to 1ms. I have set the grid accordingly, but I am not sure how to set nudge increments by ms.
I came across this image of regular Pro Tools, but in my version of Pro Tools First, the actual Nudge Value drop down menu stops at 'Triplet' - no options underneath. Is there any way I can fix this? It's my sole purpose for using any version of Pro Tools at all.
Thanks.
Old 06-21-2018, 05:54 PM
Default Re: How to set nudge settings to milliseconds in Pro Tools first?
Its right there in front of you. Min:Secs. The first digits are minutes, the middle set are seconds and the last set will be ms. Having said that, I would not use ms. I much prefer to set nudge to 100 samples(especially if I am "free-handing" for feel). But, if I am fixing timing, I would be more likely to select GRID mode(F4) and select a grid value that makes sense for the song(might be 8th note or quarter note for a slower song, sixteenth for an uptempo. The choice is dependent on why you are nudging
Old 06-22-2018, 07:47 AM
I need to be clear - that screenshot is not how my Pro Tools First looks, it's a screen shot for some regular version of Pro Tools. I can't see anything under the 'Triplets' section.
Surely I can still fix this - why would they have Elastic Audio at all in Pro Tools First if you couldn't adjust settings this way?
Old 06-22-2018, 01:05 PM
Sorry but since I can't get PT First to open on my system, I'm not able to help
Old 06-22-2018, 01:50 PM
That's OK, hopefully someone who has the software and knows it is standing by...
Old 06-23-2018, 01:07 AM
RussUK RussUK is offline
Avid has an excellent chart showing the difference between each version. Pro Tools First does not have all of the options found in Pro Tools.
http://www.avid.com/pro-tools/compar...Tools-Features
I work with amazing people who do amazing things.
Founder of the Expert Sites.
Old 06-24-2018, 04:20 AM
Well, it appears Elastic Audio is present, that was never in doubt. I just can't find a way to alter the nudge by milliseconds. It's beyond pointless to include elastic audio and not have you able to use it this way, so surely there's a way to do it? Someone must know?
Old 06-24-2018, 04:38 AM
I can't see the drop down menu that actually deals with milliseconds, as shown here. How do I get it? It's driving me insane.
http://apps.avid.com/ProToolsFirstHe...tml/wwhelp.htm
Old 06-24-2018, 08:29 AM
I'm not familiar with PT First, but can you change your main time ruler to Min:Secs, rather than Bars|Beats? If so, do the nudge values switch to increments of Min:Secs?
Scott Gatteño
Yessian
Old 06-24-2018, 08:57 AM
The above link appears to state that you can do so, but I can't see how to...
are 3 milliseconds of latency noticeable? jcche19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-25-2010 05:23 AM
Possible to change direction of Nudge 1/Nudge 8/Nudge Bank switches? EricHirsch ICON & C|24 1 08-13-2009 09:07 AM
Can't loop selections shorter then 500 milliseconds Brytbroder Pro Tools M-Powered (Win) 5 10-25-2007 02:48 PM
Milliseconds????? Peter Groom Pro Tools TDM Systems (Mac) 2 02-09-2007 07:14 AM
Midi Offset In Samples vs Milliseconds??? tomhartman Pro Tools TDM Systems (Mac) 2 07-05-2004 11:24 AM
