Re: ATSC A/85 - need some advice
-14 sounds about right for a slammed mix. If it is limited hard like you say, there are no real high peaks. When I mix for Europe R128, my limiter is around -13 or -12 (promo so it's also not very dynamic) and I don't slam it too hard. So -14 for a harder limited mix sounds about right.
johnomix.com |
By compressing the hell out of it you increased the loudness so LM correct has no other choice than bringing it all down. If I where you I'd meter while downmixing and adjust dynamics using the master-stems instead of squashing the full mix. LM correct will simply measure the loudness and then gain the entire file up or down to match the specs. So if your mix is totally squashed (=loud) it will simply gain it down. When you say your original has high dynamics it doesn't make sense to squash it all the way and then use a machine like LM correct to simply set the overall gain so that the result matches the LU. Unless of course that's not what you did. Often it's quite surprising how a regular theatrical mix is already pretty close to R128 so I was wondering why you had to squash it so much. ATSC is not that much different. frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
The mixer's responsibility is not solely that the mix complies to the standard, but he also has to keep in mind, that the dynamic range isn't too big. I did an R128 mix for ZDF once, and this has been rejected, because they found it to bee too dynamic (and it really wasn't that much). They do want a really slammed mix, just like before R128 - which I do not find to be surprising. Many viewers don't care about the "artistic qualities" of a mix. They sit at home, listening to the mix with their poor flat screen speakers and want to hear everything while eating their chips. That is why I did exactly as you thought, Frank. I mixed down first and let LM Correct do its job thereafter, knowing full well what it does. And I wasn't surprised that the mix got lower, but I didn't expect it to go down that much. So, how do you guys do it when you mix for TV? Are your ITU 1770-mixes greatly different from the old -9dB (-8dB) TV-mixes in the past in terms of dynamic range?
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
What are the figures you get when you measure the original mix? IMO, I think slamming it all before even considering the LU metering might not be the best workflow because you can throw just about anything at LMcorrect and it will output a file with the correct LU because it's a machine. The more you compress your mix the more the plugin will turn it down. That's the whole point of loudness based specs.
Yes, R128 mixes are a lot more dynamic than the old -10dbfs mixes.
Someone mentioned that there's not a lot to do to get a feature film to get within r128 specs. Hat would IMHO mean a very in dynamic feature film mix and a overly dynamic r128 mix. I do not agree that just making it within the r128 spec is enough. If you are within specs and a loudness range of over 22-25, I'd say that there may be intelligibility issues at typical TV playback levels. Personally I try to stay around 17-20 when doing a TV drama. Iit's easy to stay within the spec while having widely different dynamics. And in a way the old concept of reducing dynamics for TV s still important IMHO. I wish it wasn't, since as a sound geek I'd love to mix for an audience that cared and had the spl when watching TV loud enough so that a nice big dynamic range would work. Unfortunately that is not the case. I use myself and my everyday TV viewing as a reference. I need to be able to watch a show while the kids are sleeping next door and still hear and understand principal dialog. This means that the dialog dynamic range needs to be pretty tight IMHO. Wether it's done using fader moves or compression is not the point. Then the rest of the mix is balanced around the dialog to fit within he specs. Does it result in a mix that is less interesting if listened to at a heigher playback level? Yes, but it is still as much of a compromise as it ever was. In my case I also have to hit multiple specs as Sweden isn't yet using R128 for TV so I have a few more things to consider as well (-8/-10dbfs OR max peaks to +11 on the Nordic ppm scale, depending on what network it's going to). |
#16
No doubt there are exceptions. Of course this also depends on the range-specs of a given station. I only used R128 as an example knowing the OP needs to meet ATSC because the two standards are not extremely far away. It does get a bit weird when you have a documentary with no voice at all and they want you to reach -23. That's where the new specs fail to make sense I think.
#17
But that leaves me with this low overall-level mix, and my question is just that - is that okay and a common thing, or am I way off and need to allow a greater dynamic range therefor gaining more over all loudness? Frank, as I said, I do understand what LM Correct does, that you can feed it anything and it will either raise or lower it's volume to achieve the specs. That is exactly how I used it, and it did what I intended it to do. I didn't measure the original 5.1 mix, because that doesn't really help. I have to deliver a stereo downmix of the show, so the loudness of the 5.1 is not a reference.
#18
I meant the stereo downmix without any compression added.
#19
Meads.
If you don't have stems or original project I would not squash it that hard anyway. It's better to first reduce levels during the loud parts (where any dialog will likely be loud anyway) and raising the lower sections before adding any compression, this will sound a lot better than just squashing the loud stuff. And it will require less over all compression and going you a nicer mix. If its a VERY dynamic feature I would consider treating the centre differently to the other channels, but this takes time and is of course another compromise, but still better than squashing it all IMHO. |
#20
Frank, I just measured the Lt/Rt and it reads -12.8LKFS.
Room Calibration - ATSC Standards - Help | mikevarela | Post - Surround - Video | 20 | 08-29-2013 09:26 AM |
ATSC A/85 max level? | reichman | Post - Surround - Video | 6 | 06-14-2012 07:58 AM |
Current US Commercial Loudness Game (CALM/ATSC?) | jeremiahmoore | Post - Surround - Video | 8 | 12-21-2011 05:11 PM |
I Need Advice --- Mac or PC? | JS3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 10-24-2006 12:19 PM |
PT Mix to LE? Advice?! | RobRaden | General Discussion | 2 | 12-17-2005 12:28 PM |
