Re: USB 3 will crush eSata and Firewire800
5Gbps?!?! Can current hard drives even handle that sort of load? What other new things are coming up if they're planning for that already? Hmm...
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
This reminds me of the discussion going on a few years ago about SoundTrackPro becoming the new ProTools-killer ;-)
frank. |
This discussion reminds me of the one almost 10 years ago when Apple got rid of the Floppy disks and Serial ports on their G3s and iMacs. A number of people were up in arms about what Apple was doing. But in the end it all worked out. The items that were not directly serviced by Apple's change were addressed by third party hardware developers (Keyspan USB - Serial adapter comes to mind). I think we will all be ok. There will be a slight period of growing pains, but then we won't think much about it.
Randall Quote:
Randall Smith Audio Editor/Mixer Starz Entertainment Group Denver, CO |
What I found interesting in the article was a little tidbit that refers to the new FIREWIRE 3200 spec...
So, I did a little googling and found this: "FireWire 3200 promises a lower transfer rate of 3.2 Gbps, but boats that its P2P architecture will deliver 97% of the theoretical rate, a number that is much higher that the master/slave architecture of USB is expected to produce. As a result, it’s possible that in real world usage FireWire may actually be faster, regardless of the fact that it isn’t on paper. As far as power output, despite the improvements made by USB, FireWire still maintains an edge. It can produce more power and will therefore be more capable when it comes to charging items or running them directly. The designers have also made FireWire 3200 backwards compatible with FireWire 800, and as an added bonus you can plug a FireWire 3200 cable/device into your old FireWire 800 port and still get the full transfer rate of 3.2 Gbps." From:http://cooltechcheck.blogspot.com/20...wire-3200.html I look forward to having both interfaces in my gear. Each with its own set of purposes. Just like today. |
firewire 3200 / esata / usb3...
what gets me excited about all of these if the thought that I will be able to buy a HD system that does not require me to buy a powermac/pci-x/internal-card of some kind :) how fast would these connections have to be in order for them to be a replacement for the internal card connections that HD has now? |
#16
It means nothing until people like Dane Davis and the studios start throwing out their firewire topographies.
We used to have a saying back when I was at Creative Cafe in the late 90's and Fibre Channel arrived- Buy the Dream- Live the Nightmare.
charles maynes sound design and recording for film and media 818 618 0580 Member IATSE Local 700, MPSE, ATAS, NRA & USMCHC. |
#17
Humbug. Don't care. Still using SCSI for the heavy lifting here. Still happy.
#18
Allow me to be cynical:
- Mass production rules - "Good enough" rules - Equipment designers will find workarounds for "good enough"'s limitations. We might get PCIe FW3200 cards, but it'll be very difficult to get FW3200 in any Apple motherboard (iMac/Portables/MacPro) Firewire, as of now, is a nightmare. Mojos do not work reliably with FW hard disks attached in the same bus, and refuse completely to work with a 003 in the same bus. Generic DV bridges have the same problem, but since they only use 1/4 of the FW bus, they're more forgiving. But if FW3200 appears, someone will build a FW3200 1080p video interface and we'll be back to where we started. So, if you want to use FW video and LE, you can't use anything but a Mac Pro, because you need an expansion card for another FW bus. Heck, might as well get a Blackmagic card, then! As for eSATA, hot-plugging was never reliable enough. It seems to fail to work (necessitating a restart) or cause a kernel panic at the absolute worst possible moment. |
#19
#20
AMEN!! Ultra SCSI has a brain of its own that nothing since can compare to. Bandwidth speeds are academic if the drive doesn't know what to do with multiple requests!!
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
Pro Tools HD 7.3.1 crush on startup | Nikis | macOS | 15 | 01-13-2014 03:13 AM |
my interface make crush pt 9.0.6 | papitopinillo | Windows | 1 | 01-11-2012 11:13 AM |
FTP Server: Rumpus Or Crush | MIKEROPHONICS | Post - Surround - Video | 15 | 05-10-2011 03:42 PM |
HD9 crush on start up connectiong to DSI | shauli | Pro Tools TDM Systems (Win) | 9 | 01-10-2011 05:00 PM |
10.5.3 crush | joerusi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-29-2008 05:18 PM |
