Old 06-21-2006, 11:44 AM
Ultraslide Ultraslide is offline
Default Monitoring Problem
I am having a monitoring problem where I cannot hear an armed track, or see the level of that track when it is set to "record" but only playing back, not actually recording. I have gone thru all basic tricks (deleting prefs, databases, repair permissions, etc) . This seemed to fix the problem the last time I had it but now , nothing. I am set to auto-input monitor, and using low latency mode, changing either of these has no effect.
6.9.2 on 10.4.6. 002R.
Powermac G4 DP1.25 002R PTle 7.4
Powerbook G4 1.5 Mbox PTle 7.4
Old 06-21-2006, 11:59 AM
Default Re: Monitoring Problem
6.9.2cs4 ... btw.
thanks.
Old 06-21-2006, 01:02 PM
one note ... if I choose input-only monitoring I can hear the signal during playback, but still no meters.
i know its not supposed to work this way. i have always used auto-input monitoring, low-latency mode and had signal and meters when just monitoring an armed track against other material during playback. if I actually record i get both signal and meters in both monitoring modes.
something is buggy between the input and the software.
and ideas?
Monitoring problem- help Cal D Pro Tools M-Powered (Win) 0 08-06-2012 09:06 AM
Monitoring Problem jnrg18 Pro Tools TDM Systems (Mac) 7 12-17-2008 08:33 AM
Monitoring in HD problem thenewnoise Pro Tools TDM Systems (Mac) 13 04-27-2004 09:57 AM
monitoring problem mudflaps Tips & Tricks 1 03-26-2004 07:57 AM
Monitoring problem Steve White Pro Tools TDM Systems (Mac) 3 02-22-2004 01:08 PM
