PT M-Powered and Windows 10 ?
I have Windows 7 now and running PT M-Powered 8.0.5. I have the chance to upgrade to Windows 10. Will this PT version run on Windows 10?
Pro Tools 12.6.1 for Windows 10 ASUS Core i7 3770 Yamaha Steinberg UR 44 Golden Age Project Pre-73 JR Warm Audio WA12 MKII Preamp Glyph 1TB GPT50 external drive - Firewire LaCie 1TB external drive - USB JBL LSR305 monitors AT 2020 & 2021 Equation F.20 condenser mic |
What he said^^^ Should you try it? Absolutely! But do yourself a favor and either clone your current system drive(then pull it and install the new clone), or just pull your current drive and install a fresh drive, then load up Windows 10 and give it a go. This way, you have a backup plan
Re: PT M-Powered and Windows 10 ?
I'm having the same problem. I upgraded to Windows 10 assuming that my current applications would function. When I tried to start Pro Tools (same version you have) I had already checked the compatibility settings from the menu and selected Windows 7 as my previous version to run under. As soon as I clicked the Pro Tools icon it was kicking the computer in the gut, it went black, shut down the operating system. I had to hold in the power button to reboot. Looked everything over and tested it with the trouble shooter and it failed the same way.
Does anybody know if Avid will provide a fix? I have two older versions of Pro Tools that I paid plenty for and use constantly, now one is out of order. Any help would be appreciated. |
I don't think Avid will be doing any compatibility patches to any version of Pro Tools older than PT10 (and that I don't know about either). If you can't get it running by some hack or tweak, you'll either have to roll back to Windows 7, or look at upgrading to a newer version of Pro Tools (note that Avid haven't qualified Windows 10 for any hardware or software yet).
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
I have a feeling you are right and I'm not going to see any fix for these old versions. It's too bad because it worked perfectly fine. I'll look around to see if anybody has found a work around but it's not looking good at this point. Thanks for the input.
Me too!
I’m having trouble installing it... Computer reboot and go to recovery mode! Sent from my iPhone using Tapatalk
Windows 8 M-Powered | ajhous | Windows | 0 | 01-10-2014 10:31 AM |
M-Powered 8.0 on Windows 7? | PT8716 | Pro Tools M-Powered (Win) | 6 | 11-01-2013 11:09 AM |
ProTools M-Powered 7 on windows 7 | Lkj | Pro Tools M-Powered (Win) | 0 | 01-10-2013 03:13 AM |
M-powered 8 for windows 7 | skinse | Pro Tools M-Powered (Win) | 1 | 01-27-2012 01:26 AM |
M-Powered 7.4 on Windows & | ibanman555 | Pro Tools M-Powered (Win) | 2 | 02-07-2010 03:12 PM |
