Old 10-06-2002, 08:06 AM
ecalcagnino ecalcagnino is offline
Default Digi002 died?!?! Please help!
Ahhh!!! All of a sudden PT saya it cant communicate with the 002 and now the 002 will not "boot"! WTF? I turn it on and I get all blank scribbles, the mute is on and the faders are "stuck" in position. I can move them but the go right back to position and I can't turn any buttons on or off.
VERY uncool now that I have to cancel a session today. What the hell? Anyone else have this? Is there a "RESET" on the 002? Please help. Thanks.
Eric
There is no such thing as strong coffee, only weak people.
Eric
Old 10-06-2002, 09:23 AM
Bastiaan Bastiaan is offline
Default Re: Digi002 died?!?! Please help!
Maybe you need the firmware update?
http://duc. digidesign.com/cgi-bin/ubbcgi/ultimatebb.cgi?ubb=get_topic;f=15;t=000095
What Does This File Do?
This new Digi 002 Controller file will update the fader firmware to V105a inside of Digi 002.
This Firmware Version Resolves the Following Issues:
Changes the way the Digi 002 powers up to eliminate a possible long-term reliability issue with the fader motors.
Alleviates some cases where the scribble strips display random characters at startup and the firmware fails to initialize .
<font size="2" face="Verdana, Arial">
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 10-06-2002, 09:26 AM
I already did that the other day. It has worked since then so I am am pretty sure that I can rule that out as a potential problem. Thanks for the tip though.
Anyone else? grrr..
Eric
Eric
Old 10-06-2002, 10:23 AM
where02190 where02190 is offline
One of many reasons I do not test new hardware or software on paying clients.
Sorry for your troubles, contact digi tech support monday, or if your dealer is open today see about a replacement unit.
Old 10-06-2002, 10:48 AM
Mark_Knecht Mark_Knecht is offline
Sometimes 1394 cables or connectors go bad. What does the unit do when powered up with no connection to the PC? Have you tried reseatigng the 1394 adapter card? Is the adapter card working correctly according to Windows Device Manager?
Sorry to hear about your problems.
Good luck,
Mark
Old 10-06-2002, 11:07 AM
I have checked the card and the cables and everything is fine except the 002. It does the same thing when powered up disconnected from everything else.
Lucky for me it is my cousin's band so they are at least understanding about it.
I got this from Sweetwater so tomorrow will have to be the day I get this taken care of. It just bums me out to have spent this kind of money on something that lasted a week. I hope it is a fluke.
Thanks guys.
Eric
Eric
Old 10-07-2002, 06:46 AM
Ok, I have messed with it a bit... It will stay on for quite a while with no audio or anything hooked up but will freeze up inside of a minute with audio going through it. Any audio. I had a cd going through the ALT SRC only and it died... Seems like an overload or heat problem maybe. Who knows.
I have my calls into Sweetwater and Digi.
Help?
Eric
Eric
Old 10-07-2002, 02:47 PM
Ok, in case anyone gives a rat's behind, Digi has kindly, and quickly set up a replacement unit for me as it seems mine has actually died. Nice to be the first, isn't it. [img]images/icons/rolleyes.gif[/img]
Thanks for all the suggestions and comments folks.
Eric
Eric
Old 10-07-2002, 03:19 PM
pindebraende pindebraende is offline
Hi there
Great service by Digi. But, am I the only one thinking its a bit creepy that such an expensive, and new piece of hardware runs dead already???
Pindebraende
Best wishes,
Mikkel
Sonic Salute SFX Libraries
IMDB
Old 10-07-2002, 03:51 PM
IMO it seemes like a fluke but you never know. Sounds like Sweetwater alone got over 300 or so out the door already and according to Digi and Sweetwater I am the only one so far with any problems.
I guess I should mention that I used it for a total of about 25 hours before this happened so it's not like I beat it to death.
E
Eric
Ari Up died Carl Kolchak General Discussion 0 10-21-2010 08:04 PM
My 003 had just died. Can anyone help? bradweeks80 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-09-2010 04:49 AM
My UPS died? Stig Eliassen General Discussion 1 07-02-2008 08:02 PM
My 002 just died... sidereal-studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-13-2003 05:42 PM
002 DIED ON ME chemistry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-25-2002 01:26 AM
