Old 10-05-2002, 10:40 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default Does any one use Pro52. or Reaktor?
Hi !
I have this two plugins and i can't configure its
with my PTLE. I have other card that support
Direct conect and ASIO i don't know if this 2
things means the same but thats not the problem
How i link this plugins with pro tools LE?
The only advanced that i made is in the
midi selection on PT ( midi trak ) The other
card appear to be used but from there nothing more. [img]images/icons/confused.gif[/img]
- Jesus Alvarado -
Keep the volume UP !
Old 10-05-2002, 11:02 AM
Jonah Jonah is offline
Default Re: Does any one use Pro52. or Reaktor?
You'll have to use the other card if it's compatable because I don't think the digi card is. Then you can come off the other soundcard and into Digi in various ways depending on the outs of your other card - S/PDIF, optical or 1/4" jack.
Old 10-05-2002, 02:01 PM
KennyD KennyD is offline
They work great and ARE DirectConnect plugins that CAN be used perfectly in PTLE. Call NI and Digi support teams to help you with your best system configuration.
Old 10-05-2002, 02:04 PM
Wait!!... Windows??? oops, sorry, my bad...don't know anything about it. thought this was mac forum. Good luck!
Old 10-05-2002, 02:30 PM
jeam25's Avatar
Thanks a lot the both of you!
[img]images/icons/smile.gif[/img]
- Jesus Alvarado -
Old 10-06-2002, 01:44 AM
Mark_Knecht Mark_Knecht is offline
jeam25,
I'm playing with the AbSynth demo today. I can play it through the 001. THe latency is terrible, probably because of no ASIO support by Digi.
I suspect that to make those two work, you should choose you other sound card as the audio for the NI synths, then hook a cable up from the output of that sound card to one of the PTLE inputs.
You will not be able (as far as I know) to use them as plugins within PTLE as they are not RTAS, they are VST. No VST support in DigiLand...
Good luck,
Mark
Can Tassman or Pro52 using ASIO Run With PT 6.1.1? TriAxis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-05-2004 07:52 PM
NI Pro52 PC RTAS PeteOG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-11-2003 12:10 PM
Need help getting NI Pro52 to work Carl Fuehrer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-25-2002 12:42 PM
REAKTOR HELP!! How do you set up Reaktor to process. Christian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-10-2002 03:41 AM
pro52 problems...soft synths,sound great,when they work! pentium solitaire machine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-13-2000 05:12 PM
