can anyone tell me if there are already rtas softsynths available for the DIGI001 on windows ?
and if so ,do you need WINXP or is 98SE ok ? |
SampleTank is the only one released. You must use Win XP/5.3.1 (or possibly 5.3.2 with the 002 if Dr. Phil says it works...)
Cheers, Mark Quote:
thx for quick reply ! so it doesn't work for the DIGI 001 ? is digidesign going to do something about it ? or do we all need a 002 ? ;-)
Mark,
Sampletank runs fine on a digi001/ptle 5.1/win98 system. I think it should also run on ptle 5.0, because it runs on ptfree.....and that's basically ptle 5.0. Although sampletank is the only one available, there's also a good side to it. They offer a free version, so you can check out how it works. And i say it works pretty well. The free version is limited, so it can only use the special "free" sounds. Go take a look at www.sampletank.com (although right now its of the air...)
What's that? - That's the machine that goes "pling". Bastiaan |
Both Sampletank and Pro 52 Digi Editions work great with the XP / Digi 002 combo.
There is a documented bug with the NI Pro 52 though - you get a nasty digital noise burst if you put a reverb on the same track as the Pro 52. If you use an aux bus for the verb, it's a non-issue. There's a d/l on the NI site that fixes the problem.
Phil O'Keefe |
Sweet! [img]images/icons/cool.gif[/img]
Phil O'Keefe |
Older RTAS softsynths | Gothboy | Virtual Instruments | 1 | 07-29-2006 04:53 AM |
RTAS RMX and other softsynths crashes | eljodon | Pro Tools TDM Systems (Mac) | 17 | 07-22-2005 08:58 PM |
RTAS SoftSynths | darkglass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-28-2004 02:42 PM |
RTAS Instruments for PT LE on Windows | Mark Holloway | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 04-04-2003 07:10 PM |
RTAS Softsynths??? | who | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-22-2002 01:36 AM |
